imagesbyjas
Flight distance : 286198 ft
Ken,
Adding the 4K camera is totally supported and in fact listed in the literature provided by DJI with the P3 Professional 4K Camera. I will be more than glad to take a picture of the card supplied by DJI showing the compatibility of cameras and aircraft. If you have a new one (in a box) there, you will find the card on the top of the packaging. The 4K camera IS listed as compatible and acceptable change for the P3A. Your own tech support took me through the steps of just making sure that a freshly formatted Micro SD has the P3P firmware on it, which I did. The DJI GO app immediately recognized the Aircraft as a Professional now.
Hopefully that will allow us to get back on the question as to why the FW 1.8 might want to upgrade the camera. The camera was purchased at B&H who is a licensed DJI distributor. I know that jumping some levels can cause issues. I do not see a way to find out which level is on the camera, but whatever level it is, is happy with 1.7.
I need to find out if there is a problem applying this firmware. The P3A and P3P aircraft are the same. It is the circuitry in the top part of the gimbal assembly, talking to the camera, which reports back to the app which model it is, Advanced or Professional.
Hope this helps from my side.. Can you advise further from yours?
Thanks again..
Jay S. |
