Just go to the Go app Main flight screen open "General Settings " Go to the Transmitter "RC Settings " toward the bottom you will see linking the RC. Just follow the Simple instructions from there. There is also a tutorial on how to do it as well. Make sure beforehand you can locate the "Link " button on the Aircraft . It is on the aircraft's Right hand side towards the front Just behind the Nose of the aircraft, near the assembly screw. Easy peasy lemon squeezy. You could also try a Reset of The video It is real simple .
Press the C1 + C2 + Trigger (photo) buttons and keep them pressed and TURN OFF the controller.
By still keeping pressed the C1 + C2 + Trigger (photo) buttons TURN ON the controller.
The RC Calibration is under the RC settings as well, just go to RC calibration and follow the Simple Steps. Make sure you only go in the direction indicated on the display.
I think I would do this first, and then the Re-link if your signal does not improve.
Donnie
