endotherm
![](https://forum44.djicdn.com/data/attachment/common/9b/common_15_usergroup_icon.png) First Officer
Flight distance : 503241 ft
ombravo Posted at 2017-10-25 17:48
Hi, anybody got this problem solved, in my case I flew with no problems four months ago until today that I connected everything normally and found this message and the drone connects for like 5 seconds but no image signal and then disconnects from the app, but the controller shows green light all the time. I asume it´s an app issue, this is very strange. Thanks in advance for any advice
It's more likely to be a hardware issue than an app issue. As I mentioned above in post #10, I had it appear due to intermittent contact with the wiring from the USB module on the bottom of the controller. It could be the connectors or the ribbon cable, or it could be the circuitry in the module itself or the USB plug. It is reporting that the serial bus information is being interrupted. Have you changed this module recently, such as adding the HDMI functionality?
The controller will still function correctly, this error only affects your screen device and the data flowing between the controller and the device. It's much the same as if you have a broken USB cable between your PC and an external device. The controller itself is a "dumb" radio remote control and will still fly the aircraft through the joystick commands and physical buttons. That's why you still have a green light. It's all the software controlled stuff that you access through the screen that isn't reliable. |
