Another Phantom fell out of the sky...
1249 14 2016-7-20
rebsfan22
Flight distance : 29774 ft
Just got my replacement P3S yesterday, and was flying it over my driveway 20ft up and 20ft away from me.  All was good, then it randomly stopped and crashed down on the concrete.  Gimbal arm snapped, and some of the cables tore.  UGH.  So frustrated.
2016-7-20
theeasynine
Sorry to hear that. Seems until they get the firmware issue fixed everybody should just not buy the Standard. Too many horror stories.
2016-7-20
rebsfan22
theeasynine Posted at 2016-7-21 08:42
Sorry to hear that. Seems until they get the firmware issue fixed everybody should just not buy the  ...
I had it out 938ft away at one point, and it was flying perfectly.  Makes no sense to me.
2016-7-20
msduncanrolltid
Flight distance : 1669012 ft
You sure you didn't issue the kill command?
2016-7-20
rebsfan22
msduncanrolltid Posted at 2016-7-21 08:56
apparently I did.  Wish there was a way to disable it.
2016-7-20
billwish76
Flight distance : 175495 ft
My p3s works fine with update but rumors has it there wont be any new fw for p3s
2016-7-20
Flying Poptart
Flight distance : 734577 ft
So sorry about your crash.....
2016-7-20
DJI-H.C
Hi, sorry about your loss.  You can use your DJI Go to open the flight log and check your command input. It's rare for the drone to just fall out of sky without outside force.
You can also contact support@dji.com and send the drone for inspection, they'll give you a quote on the repair fee.
Thank you.
2016-7-20
rebsfan22
DJI-H.C Posted at 2016-7-21 10:45
Hi, sorry about your loss.  You can use your DJI Go to open the flight log and check your command in ...
I did the CSC input (both sticks down and out).  Why was the input changed on the 4, but never on the 3 via update?  Seems like it was definitely an issue, since it got changed.
2016-7-20
04red6
Flight distance : 5484997 ft
So it did not fall out of the sky, you cut the motors and made it fall. So user error. Correct? How did you get in a situation that the sticks were the CSC position. That is an odd position to have the sticks in unless you are flying like a maniac?
2016-7-20
rebsfan22
04red6 Posted at 2016-7-21 11:19
So it did not fall out of the sky, you cut the motors and made it fall. So user error. Correct? How  ...
It did fall out of the sky....  I was yawing and turning to land.  Used to flying quads that can handle it, so I didn't think twice about it.  Live and learn.
2016-7-20
endotherm
Flight distance : 503241 ft
rebsfan22 Posted at 2016-7-21 13:36
It did fall out of the sky....  I was yawing and turning to land.  Used to flying quads that can h ...
Yawing and turning is just fine.
Maximum right yaw  + maximum down + maximum back + maximum rotate left all at once = CSC = crash.  Equally bad is:
Maximum left yaw  + maximum down + maximum back + maximum rotate right all at once = CSC = crash.  Eliminate one or more steps and you'll be fine.  You'd have to agree these maneuvers are pretty insane.
2016-7-21
wmcvey
Flight distance : 904364 ft
theeasynine Posted at 2016-7-20 20:42
Not true, My P3S is top notch. No issues, works great. Been out to 1000m before turning back.
2016-7-21
wmcvey
endotherm Posted at 2016-7-21 09:37
Maximum right yaw  + maximum down + maximum back + maximum rotat ...
Another thread with an eye catching heading trying to put fault on the equipment, or software. At least he owned up to it being pilot error, not equipment malfunction. But now it's the method of CSC that's at fault. I  wish people would stop posting and pointing fault at the software or equipment until their sure it wasn't their own doing.
2016-7-21
guns&cameras
Damn..sorry to hear that man...
2016-7-21
