MD_Icarus
Aloha Back!
I thought the P4 camera communicates in the 5.8 GHZ frequency? or is that for the Inspire only? My spectrum analyzer is not working so I can not test it right now. Maybe DJI / beta testers can shed some light.
It seems that the P4 RC is supposed to put out +23 dBm at the 2.4 GHZ frequency; but I do not see any specs for the P4 craft power though? I suspect that the ultimate solution is to mod both the RC, as well as the P4. It makes no sense to boost the RC to get you 25000 feet, if the P4 signal will not reach the RC at a distance above 8000 feet!
I personally do not think they can do anything by firmware to increase power, as they have to abide by the current approved FCC spec.
But maybe some changes can be made on the video compression side, working with apple or at least give us the auto option with 4 mbbs.
IMO,
If there are no technical obstacles to give us the option to set the video to 4MBBS/AUTO, which will allow the maximum range, and they do not, then they are either under pressure to limit the P4 range, or it is a marketing strategy.
As far as evaluation,
I have used 2 RC's with similar results. I think the power output tolerance between RC's is not that bad, so I doubt they will find an RC with more power. The older P3A RC's tend to put out more power though. They are the ones with the A at the end of the model number. It seems that the latest RC with the C at the end of the model number is the most power challenged RC ever made? If you google it you will see many such reports.
