Defective Lens and Gimbal?
5430 18 2016-7-5
mfojas430
Flight distance : 23835 ft
I got my P3S a week or 2 ago. I went to wipe it down as it got a little dusty from flying and I noticed a streak on the lens. I tried to wipe it off but it wouldn't come off. See pictures. It's kind of hard to see. Is this an issue with the lens? I want to get it taken care of while I can.
Edit: I saw another post from someone asking about their gimbal getting really hot. Mine also gets hot, but I thought it was normal. Need some advice here.
2016-7-5
DJI-Paladin
Flight distance : 2408 ft
Hello mfojas430, it would be better to post a high resolution picture here. Mark on the streak will be appreciated.Thank you.
2016-7-6
mfojas430
I'll try to do that later today. The streak is visible in the pictures I posted, but pretty faint. If you look at the first picture, you can see the streak toward the center of the lens. If you reference the DJI logo at the bottom of the lens, the streak is above that and slightly to the left.
2016-7-19
DJI-Jamie
Flight distance : 112405 ft
mfojas430@insit Posted at 2016-7-19 23:04
I'll try to do that later today. The streak is visible in the pictures I posted, but pretty faint. I ...
Have you also tried using a non streaking lens cleaner with a non abrasive cleaning cloth? Does the streak fill like an indent?
2016-7-20
mfojas430
DJI-Jamie Posted at 2016-7-20 17:04
Have you also tried using a non streaking lens cleaner with a non abrasive cleaning cloth? Does th ...
I tried wiping it with a microfiber cloth. It didn't feel like an indent nor residue that was on the lens.
2016-7-21
DJI-Jamie
mfojas430@insit Posted at 2016-7-22 00:35
I tried wiping it with a microfiber cloth. It didn't feel like an indent nor residue that was on t ...
Do you see any improvement from wiping or using a lens cleaner?
2016-7-21
mfojas430
DJI-Jamie Posted at 2016-7-21 13:00
No, I didn't see any change. I don't notice anything in my videos, but I'd rather have it repaired while I can. I keep forgetting to upload better pictures. Let me set a reminder fo rmyself.
2016-7-25
DJI-Jamie
mfojas430@insit Posted at 2016-7-26 03:05
No, I didn't see any change. I don't notice anything in my videos, but I'd rather have it repaired ...
You would be able to have this issue addressed in no time. Have you already started the RMA process with the North American Support team?
2016-7-26
mfojas430
No, I haven't started the RMA process. I'm not even sure how to do that. I attached a few more HD pics and a video which should help show what's on the lens better. I think Pic 1 and Pic 3 are the best and the video should show it as I move the camera around to show it's not a reflection. It's tricky trying to get a good shot of it because sometimes it looks like a reflection.
Picture 1
Picture 2
2016-7-26
mfojas430
DJI-Jamie Posted at 2016-7-26 14:51
You would be able to have this issue addressed in no time. Have you already started the RMA proces ...
Posted some better pictures
2016-7-28
DJI-Jamie
mfojas430@insit Posted at 2016-7-28 23:27
That looks like some sort of damage to the lens that would require a RMA. Based on your location, you can contact the North American Repair facility by either emailing support.us@dji.com or calling 818-235-0789.
2016-7-28
Viridis
Flight distance : 2383556 ft
Looks like the uv filter has come away from the glass, common with mobile phones that have the uv filter on the outside.
2016-7-29
mfojas430
Viridis Posted at 2016-7-29 03:33
Looks like the uv filter has come away from the glass, common with mobile phones that have the uv fi ...
Do 3 standards have UV filters on them?
2016-7-29
Viridis
If the whole glass has a dark purple red sheen when looked at with sunlight on it, yes it's a uv filter layer.
2016-7-29
DJI-Jamie
mfojas430@insit Posted at 2016-7-29 21:29
It does have a UV lens, but it is not removable unlike its P3 Pro and Advance counterparts.
2016-7-29
mfojas430
DJI-Jamie Posted at 2016-7-29 19:18
Okay. That maybe the problem then. I received an RMA. I just need to find a box to use to send it in.
2016-8-1
DJI-Jamie
mfojas430@insit Posted at 2016-8-2 02:32
Okay. That maybe the problem then. I received an RMA. I just need to find a box to use to send it  ...
Thank you for the update, you'll be up and running again in no time.
2016-8-1
mfojas430
DJI-Jamie Posted at 2016-8-1 16:00
I hope so!
2016-8-1
mfojas430
Update: 8/17/19 - Just sent my phantom out for service. Will post more updates as it goes through the repair process.
RMA: 0728201619317328016
Case: 264175
UPS Tracking #: 1ZE80E409092170658
Update 8/19 - Received confirmation email from DJI that my Phantom was received.
Repair Tracking #: 160820KY5-P3C0632
Update 8/23 - Received email notification from DJI that my Phantom was shipped out. UPS Tracking #: 1ZE80E404246526478
Update 8/25 - Unit received. Will inspect and post my results.
Update 9/2 - I'm a bit disappointed as I write this. The quad itself looks great. But I am unable to connect it to the DJI GO app and the new camera makes same clicking noise when tilting up. It hinders the cameras movement up if you would fly forward. See video. Creating a post in the P3 section to see if I can get any help with the app. I think that I will have to send it back again after just receiving it to have the camera fixed again.
Update 9/3 - Happy again now the the issues have been resolved. Relinking the transmitter fixed the app issue and I can now get the video feed. The clicking. Was due to the ribbon being slight backed out from the camera. Pushed the ribbon in, and the clicking sound is gone.
2016-8-17
