Issue with my DJI OSMO
1045 8 2016-8-25
ii2110
Brunei
Hi!I was trying to update the osmo software so i downloaded the file and extracted it to the osmo SD card.Once i switched on the osmo,the right light turns red and the left light is green/yellow.It remains like that for a few seconds until it automatically switches off.My battery is already full and I've tried it several times but results are the same.
2016-8-25
DJI-Jessie
Hello ii2110,could you please upload the upgrade log file here?
2016-8-25
ii2110
Brunei
DJI-Jessie Posted at 2016-8-26 14:03
how do i find and upload the upgrade log file?
2016-9-1
ii2110 Posted at 2016-9-1 20:41
Please find the hidden LOG file by following these steps:
1. Enable Viewing hidden files in your OS. Below are the websites where you can check how to show the hidden files in your PC.
For The Windows System:
http://windows.microsoft.com/en- ... den-files=windows-7
For The Mac System:
http://ianlunn.co.uk/articles/qu ... mac-os-x-mavericks/
2.Enter the root directory of the SD card, then find the hidden folder MISC and enter it. There is LOG folder in it.
3.The LOG txt file is under the LOG folder.
2016-9-1
ii2110
Brunei
[00008983]Delete history success.
[00009204]========== remo-con disconnect. boot(15) ============
[00009263]Packet [C:\OSMO_FW_V01.05.02.00.bin] detected, card sn [0x43ede6fe].
[00009320]Packet upgrade start...
[00009378]Packet checking...
[00009442]Packet vlink 01.05.0200 <-> 01.04.0180.
[00009504]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00009559]Done.
[00009615]Version checking[1]...
[00009724][07 00][00] v1.0.9.48 -> v1.0.9.48
[00009784][08 00][00] v2.14.9.42 -> v2.14.9.42
[00009848][01 00][00] v2.63.4998 -> v2.63.4998
[00009906][01 01][00] v2.63.4998 -> v2.63.4998
[00009971][04 00][00] v1.29.0.91 -> v1.29.0.91
[00010044][09 00][00] v0.0.0.78 -> v0.0.0.78
[00012102]Packet upgrade cancelled at version checking.
[00008703]========== remo-con disconnect. boot(15) ============
[00008759]Packet [C:\OSMO_FW_V01.05.02.00.bin] detected, card sn [0x43ede6fe].
[00008817]Packet upgrade start...
[00008876]Packet checking...
[00008935]Packet vlink 01.05.0200 <-> 01.04.0180.
[00009000]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00009056]Done.
[00009110]Version checking[1]...
[00009205][07 00][00] v1.0.9.48 -> v1.0.9.48
[00009279][08 00][00] v2.14.9.42 -> v2.14.9.42
[00009334][01 00][00] v2.63.4998 -> v2.63.4998
[00009391][01 01][00] v2.63.4998 -> v2.63.4998
[00009469][04 00][00] v1.29.0.91 -> v1.29.0.91
[00009537][09 00][00] v0.0.0.78 -> v0.0.0.78
[00011593]Packet upgrade cancelled at version checking.
[00006812]========== remo-con disconnect. boot(15) ============
[00006875]Packet [C:\OSMO_FW_V01.05.02.00.bin] detected, card sn [0x43ede6fe].
[00006945]Packet upgrade start...
[00007009]Packet upgrade failed at state checking (esc = 0).
[00008791]========== remo-con disconnect. boot(15) ============
[00008843]Packet [C:\OSMO_FW_V01.05.02.00.bin] detected, card sn [0x43ede6fe].
[00008897]Packet upgrade start...
[00008953]Packet checking...
[00009008]Packet vlink 01.05.0200 <-> 01.04.0180.
[00009060]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00009217]Done.
[00009272]Version checking[1]...
[00009347][07 00][00] v1.0.9.48 -> v1.0.9.48
[00009403][08 00][00] v2.14.9.42 -> v2.14.9.42
[00009457][01 00][00] v2.63.4998 -> v2.63.4998
[00009515][01 01][00] v2.63.4998 -> v2.63.4998
[00009590][04 00][00] v1.29.0.91 -> v1.29.0.91
[00009657][09 00][00] v0.0.0.78 -> v0.0.0.78
[00011710]Packet upgrade cancelled at version checking.
[00008797]========== remo-con disconnect. boot(15) ============
[00008850]Packet [C:\OSMO_FW_V01.05.02.00.bin] detected, card sn [0x43ede6fe].
[00008902]Packet upgrade start...
[00008959]Packet checking...
[00009015]Packet vlink 01.05.0200 <-> 01.04.0180.
[00009074]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00009126]Done.
[00009184]Version checking[1]...
[00009259][07 00][00] v1.0.9.48 -> v1.0.9.48
[00009322][08 00][00] v2.14.9.42 -> v2.14.9.42
[00009376][01 00][00] v2.63.4998 -> v2.63.4998
[00009433][01 01][00] v2.63.4998 -> v2.63.4998
[00009498][04 00][00] v1.29.0.91 -> v1.29.0.91
[00009579][09 00][00] v0.0.0.78 -> v0.0.0.78
[00011634]Packet upgrade cancelled at version checking.
[00008909]========== remo-con disconnect. boot(15) ============
[00008964]Packet [C:\OSMO_FW_V01.05.02.00.bin] detected, card sn [0x43ede6fe].
[00009022]Packet upgrade start...
[00009081]Packet checking...
[00009138]Packet vlink 01.05.0200 <-> 01.04.0180.
[00009192]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00009257]Done.
[00009314]Version checking[1]...
[00009401][07 00][00] v1.0.9.48 -> v1.0.9.48
[00009485][08 00][00] v2.14.9.42 -> v2.14.9.42
[00009540][01 00][00] v2.63.4998 -> v2.63.4998
[00009597][01 01][00] v2.63.4998 -> v2.63.4998
[00009681][04 00][00] v1.29.0.91 -> v1.29.0.91
[00009751][09 00][00] v0.0.0.78 -> v0.0.0.78
[00011808]Packet upgrade cancelled at version checking.
[00008798]========== remo-con disconnect. boot(15) ============
[00008852]Packet [C:\OSMO_FW_V01.05.02.00.bin] detected, card sn [0x43ede6fe].
[00008977]Packet upgrade start...
[00009034]Packet checking...
[00009095]Packet vlink 01.05.0200 <-> 01.04.0180.
[00009149]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00009204]Done.
[00009257]Version checking[1]...
[00009336][07 00][00] v1.0.9.48 -> v1.0.9.48
[00009407][08 00][00] v2.14.9.42 -> v2.14.9.42
[00009461][01 00][00] v2.63.4998 -> v2.63.4998
[00009521][01 01][00] v2.63.4998 -> v2.63.4998
[00009596][04 00][00] v1.29.0.91 -> v1.29.0.91
[00009667][09 00][00] v0.0.0.78 -> v0.0.0.78
[00011722]Packet upgrade cancelled at version checking.
[00009339]========== remo-con disconnect. boot(15) ============
[00009428]Packet [C:\OSMO_FW_V01.05.02.00.bin] detected, card sn [0x43ede6fe].
[00009500]Packet upgrade start...
[00009569]Packet checking...
[00009626]Packet vlink 01.05.0200 <-> 01.04.0180.
[00009694]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00009747]Done.
[00009808]Version checking[1]...
[00009904][07 00][00] v1.0.9.48 -> v1.0.9.48
[00009988][08 00][00] v2.14.9.42 -> v2.14.9.42
[00010039][01 00][00] v2.63.4998 -> v2.63.4998
[00010102][01 01][00] v2.63.4998 -> v2.63.4998
[00010181][04 00][00] v1.29.0.91 -> v1.29.0.91
[00010258][09 00][00] v0.0.0.78 -> v0.0.0.78
[00012312]Packet upgrade cancelled at version checking.
[00008706]========== remo-con disconnect. boot(15) ============
[00008760]Packet [C:\OSMO_FW_V01.05.02.00.bin] detected, card sn [0x43ede6fe].
[00008812]Packet upgrade start...
[00008872]Packet checking...
[00008925]Packet vlink 01.05.0200 <-> 01.04.0180.
[00008985]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00009038]Done.
[00009092]Version checking[1]...
[00009167][07 00][00] v1.0.9.48 -> v1.0.9.48
[00009227][08 00][00] v2.14.9.42 -> v2.14.9.42
[00009282][01 00][00] v2.63.4998 -> v2.63.4998
[00009335][01 01][00] v2.63.4998 -> v2.63.4998
[00009401][04 00][00] v1.29.0.91 -> v1.29.0.91
[00009487][09 00][00] v0.0.0.78 -> v0.0.0.78
[00011637]Packet upgrade cancelled at version checking.
[00008696]========== remo-con disconnect. boot(15) ============
[00008750]Packet [C:\OSMO_FW_V01.05.02.00.bin] detected, card sn [0x43ede6fe].
[00008802]Packet upgrade start...
[00008859]Packet checking...
[00008914]Packet vlink 01.05.0200 <-> 01.04.0180.
[00008974]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00009026]Done.
[00009082]Version checking[1]...
[00009154][07 00][00] v1.0.9.48 -> v1.0.9.48
[00009214][08 00][00] v2.14.9.42 -> v2.14.9.42
[00009271][01 00][00] v2.63.4998 -> v2.63.4998
[00009325][01 01][00] v2.63.4998 -> v2.63.4998
[00009391][04 00][00] v1.29.0.91 -> v1.29.0.91
[00009474][09 00][00] v0.0.0.78 -> v0.0.0.78
[00011527]Packet upgrade cancelled at version checking.
[00008698]========== remo-con disconnect. boot(15) ============
[00008751]Packet [C:\OSMO_FW_V01.05.02.00.bin] detected, card sn [0x43ede6fe].
[00008803]Packet upgrade start...
[00008860]Packet checking...
[00008915]Packet vlink 01.05.0200 <-> 01.04.0180.
[00009027]Done.
[00009083]Version checking[1]...
[00009155][07 00][00] v1.0.9.48 -> v1.0.9.48
[00009213][08 00][00] v2.14.9.42 -> v2.14.9.42
[00009270][01 00][00] v2.63.4998 -> v2.63.4998
[00009323][01 01][00] v2.63.4998 -> v2.63.4998
[00009476][09 00][00] v0.0.0.78 -> v0.0.0.78
[00011528]Packet upgrade cancelled at version checking.
[00009103]========== remo-con disconnect. boot(15) ============
[00009157]Packet [C:\OSMO_FW_V01.05.02.00.bin] detected, card sn [0x43ede6fe].
[00009209]Packet upgrade start...
[00009266]Packet checking...
[00009319]Packet vlink 01.05.0200 <-> 01.04.0180.
[00009374]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00009426]Done.
[00009480]Version checking[1]...
[00009557][07 00][00] v1.0.9.48 -> v1.0.9.48
[00009615][08 00][00] v2.14.9.42 -> v2.14.9.42
[00009670][01 00][00] v2.63.4998 -> v2.63.4998
[00009826][01 01][00] v2.63.4998 -> v2.63.4998
[00009902][04 00][00] v1.29.0.91 -> v1.29.0.91
[00009967][09 00][00] v0.0.0.78 -> v0.0.0.78
[00012020]Packet upgrade cancelled at version checking.
[00009100]========== remo-con disconnect. boot(15) ============
[00009155]Packet [C:\OSMO_FW_V01.05.02.00.bin] detected, card sn [0x43ede6fe].
[00009213]Packet upgrade start...
[00009270]Packet checking...
[00009331]Packet vlink 01.05.0200 <-> 01.04.0180.
[00009386]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00009441]Done.
[00009498]Version checking[1]...
[00009656][07 00][00] v1.0.9.48 -> v1.0.9.48
[00009723][08 00][00] v2.14.9.42 -> v2.14.9.42
[00009782][01 00][00] v2.63.4998 -> v2.63.4998
[00009839][01 01][00] v2.63.4998 -> v2.63.4998
[00009919][04 00][00] v1.29.0.91 -> v1.29.0.91
[00009985][09 00][00] v0.0.0.78 -> v0.0.0.78
[00012042]Packet upgrade cancelled at version checking.
[00009018]========== remo-con disconnect. boot(15) ============
[00009083]Packet [C:\OSMO_FW_V01.05.02.00.bin] detected, card sn [0x43ede6fe].
[00009137]Packet upgrade start...
[00009208]Packet checking...
[00009269]Packet vlink 01.05.0200 <-> 01.04.0180.
[00009323]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00009388]Done.
[00009451]Version checking[1]...
[00009535][07 00][00] v1.0.9.48 -> v1.0.9.48
[00009612][08 00][00] v2.14.9.42 -> v2.14.9.42
[00009667][01 00][00] v2.63.4998 -> v2.63.4998
[00009722][01 01][00] v2.63.4998 -> v2.63.4998
[00009808][04 00][00] v1.29.0.91 -> v1.29.0.91
[00009875][09 00][00] v0.0.0.78 -> v0.0.0.78
[00011928]Packet upgrade cancelled at version checking.
[00010504]========== remo-con disconnect. boot(15) ============
[00010559]Packet [C:\OSMO_FW_V01.06.02.10.bin] detected, card sn [0x43ede6fe].
[00010619]Packet upgrade start...
[00010675]Packet checking...
[00010733]Packet vlink 01.06.0210 <-> 01.05.0200.
[00010793]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00010926]Done.
[00010986]Version checking[1]...
[00011055][07 00][00] v1.0.9.48 -> v1.0.9.48
[00011125][08 00][00] v2.14.9.42 -> v2.14.9.42
[00011186][01 00][00] v2.63.4998 -> v2.65.5033 need upgrade
[00011238][01 01][00] v2.63.4998 -> v2.65.5033 need upgrade
[00011322][04 00][00] v1.29.0.91 -> v1.29.0.92 need upgrade.
[00011384][09 00][00] v0.0.0.0 -> v0.0.0.81 need upgrade.
[00011434]Done.
[00013495]Waiting for user confirm...
[00023551]Timeout, start upgrade automatically.
[00023668]Firmware upgrading[1]...
[00029404][01 00] Firmware upgrade start...
[00018328][01 00] Firmware upgrade finished successfully.
[00018391]Done.
[00018444]Packet [C:\OSMO_FW_V01.06.02.10.bin] resumed, card sn [0x43ede6fe].
[00018508]Packet vlink 01.06.0210 <-> 01.05.0200.
[00018569]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00018632]Version checking[2]...
[00018730][07 00][00] v1.0.9.48 -> v1.0.9.48
[00018799][08 00][00] v2.14.9.42 -> v2.14.9.42
[00018857][01 00][05] v2.65.5033 -> v2.65.5033
[00018920][01 01][00] v2.63.4998 -> v2.65.5033 need upgrade
[00018978][04 00][00] v1.29.0.91 -> v1.29.0.92 need upgrade.
[00019045][09 00][00] v0.0.0.0 -> v0.0.0.81 need upgrade.
[00019106]Done.
[00019163]Firmware upgrading[2]...
[00019279][01 01] Firmware upgrade start...
[00029630][01 01] Firmware upgrade finished successfully.
[00029708][09 00] Firmware upgrade start...
[00085904]Packet upgrade stopped, enter sleep mode.
[00010512]========== remo-con disconnect. boot(15) ============
[00010567]Packet [C:\OSMO_FW_V01.06.02.10.bin] detected, card sn [0x43ede6fe].
[00010627]Packet upgrade start...
[00010678]Packet checking...
[00010738]Packet vlink 01.06.0210 <-> 01.05.0200.
[00010798]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00010856]Done.
[00010912]Version checking[1]...
[00010994][07 00][00] v1.0.9.48 -> v1.0.9.48
[00011050][08 00][00] v2.14.9.42 -> v2.14.9.42
[00011107][01 00][00] v2.65.5033 -> v2.65.5033
[00011163][01 01][00] v2.65.5033 -> v2.65.5033
[00011344][04 00][00] v1.29.0.91 -> v1.29.0.92 need upgrade.
[00011413][09 00][00] v0.0.0.0 -> v0.0.0.81 need upgrade.
[00011470]Done.
[00013529]Waiting for user confirm...
[00023579]Timeout, start upgrade automatically.
[00023690]Firmware upgrading[1]...
[00023773][09 00] Firmware upgrade start...
[00078433]Packet upgrade stopped, enter sleep mode.
[00010510]========== remo-con disconnect. boot(15) ============
[00010569]Packet [C:\OSMO_FW_V01.06.02.10.bin] detected, card sn [0x43ede6fe].
[00010629]Packet upgrade start...
[00010685]Packet checking...
[00010742]Packet vlink 01.06.0210 <-> 01.05.0200.
[00010859]Done.
[00010909]Version checking[1]...
[00010992][07 00][00] v1.0.9.48 -> v1.0.9.48
[00011056][08 00][00] v2.14.9.42 -> v2.14.9.42
[00011108][01 00][00] v2.65.5033 -> v2.65.5033
[00011168][01 01][00] v2.65.5033 -> v2.65.5033
[00011234][04 00][00] v1.29.0.91 -> v1.29.0.92 need upgrade.
[00011315][09 00][00] v0.0.0.0 -> v0.0.0.81 need upgrade.
[00011373]Done.
[00013433]Waiting for user confirm...
[00023486]Timeout, start upgrade automatically.
[00023611]Firmware upgrading[1]...
[00023691][09 00] Firmware upgrade start...
[00091884]Packet upgrade stopped, enter sleep mode.
[00010511]========== remo-con disconnect. boot(15) ============
[00010566]Packet [C:\OSMO_FW_V01.06.02.10.bin] detected, card sn [0x43ede6fe].
[00010625]Packet upgrade start...
[00010681]Packet checking...
[00010801]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00010859]Done.
[00010915]Version checking[1]...
[00010997][07 00][00] v1.0.9.48 -> v1.0.9.48
[00011067][08 00][00] v2.14.9.42 -> v2.14.9.42
[00011126][01 00][00] v2.65.5033 -> v2.65.5033
[00011178][01 01][00] v2.65.5033 -> v2.65.5033
[00011244][04 00][00] v1.29.0.91 -> v1.29.0.92 need upgrade.
[00011311][09 00][00] v0.0.0.0 -> v0.0.0.81 need upgrade.
[00011443]Done.
[00013502]Waiting for user confirm...
[00023554]Timeout, start upgrade automatically.
[00023672]Firmware upgrading[1]...
[00023751][09 00] Firmware upgrade start...
[00073948]Packet upgrade stopped, enter sleep mode.
2016-9-5
ii2110
Brunei
^is this what you wanted?
2016-9-5
ii2110 Posted at 2016-9-5 21:32
Hi, please format your SD card, then put the .bin file in your SD card(only 1 bin file at one time), put the SD card in Osmo and press “trigger+record(red dot)+power switch” buttons together for about 5 seconds, your Osmo will start updating and blinking red and green for about ten minutes and stops.  The issue should be fixed then.
2016-9-6
ii2110
Brunei
DJI Mindy Posted at 2016-9-7 15:34
Hi, please format your SD card, then put the .bin file in your SD card(only 1 bin file at one time ...
can you explain more on the .bin file once at a time?what i usually do is download the firmware form the dji website.then when i copy the .bin file(ctrl+c),it opens an app and starts extracting.then i copy that to the sd card.is that how u are supposed to do it?
2016-9-7
ii2110 Posted at 2016-9-7 20:36
can you explain more on the .bin file once at a time?what i usually do is download the firmware fo ...
You could refer to the video tutorial below.And if still no improvement, you need to email support@dji.com and send it in for fixing.
2016-9-7
