phantom 4 no activation out of the box
2396 12 2016-9-23
btm1008
Hello everyone-
Bought a new Phantom 4 yesterday....got it home.  took out of box.  Charged up everything.  Downloaded the DJI GO app to my ipad air 2.  went to the quick start guide. and followed the steps.
Power up remote
Power up drone
plug cable from remote to ipad
nothing happens -- the activation screen doesn't appear (or request for firmware update) and the app stays on the main screen - cant access the equipment icon lower left corner.
This is my second phantom 4.  I bought one for the kids.  My first one worked perfect out of the box.  So it's not like I haven't done this once already.  Yet here I am lost....
Any advice anyone?
Also this is a completely separate ipad air 2 from my other one for my first phantom 4.   Both units are independent in that sense.  Not trying to share anything between the two yet no activation process begins....
Thanks in advance.
2016-9-23
PhanFran
Flight distance : 4804163 ft
did you register with DJI ?
2016-9-23
btm1008
PhanFran Posted at 2016-9-23 15:03
It wont even give me that step this time -- nothing happens from the app.
2016-9-23
labroides
btm1008 Posted at 2016-9-24 05:23
Try pulling the cable and reconnecting it.
2016-9-23
labroides@yahoo Posted at 2016-9-24 07:36
I agree, if you did power it up in the sequence you mewntioned:
Power up remote
Power up drone
Then it probably would not work. The correct sequence is to:
Connect iPad to Remote and switch on iPad.
Power up remote
Power up aircraft
2016-9-23
bayguy69
Flight distance : 944275 ft
Puerto Rico
btm1008 Posted at 2016-9-23 15:23
Another thing to check is If the LED on the remote is Green then your P4 is connected to the remote. Then try with the connection between the iPad and the remote. It happens to me most of the time. Simply disconnect the iPad and reconnect and  it supposed to solve the problem.
2016-9-23
DJI Natalia
Hi sir, agree with them, in addition, please try to delete APP and re-install it, or change another mobile device to have a test.
BTW, may I have the aircraft SN which located in battery compartment.
2016-9-23
peter
Flight distance : 545377 ft
Also try another cable...
2016-9-24
bobasbury
Flight distance : 1140502 ft
Did you click on ME in the lower right corner of DJI GO to log in?
2016-9-24
btm1008
This was the problem actually -- a bad cable straight out of the box from an amazon supplier.  Used my original cable and it activated and registered and firmware updated all fine.  Great suggestion!  Sometimes new is not always New.....
2016-9-24
btm1008
Well everyone it would appear it was the cable from the remote to the Ipad was the issue.....  Thanks everyone for the suggestions.  It was actually the thought of one of you to not assume my new cable straight out of the box would be bad - but it was.  Must of been made on a Friday at the manufacture at quitting time.... LOL  Once I used my original cable from drone #1 - everything registered - activated and firmware updated just fine.
Thanks again everyone!
2016-9-24
btm1008
bayguy69 Posted at 2016-9-23 18:50
Another thing to check is If the LED on the remote is Green then your P4 is connected to the remot ...
Green light on remote is lit -- it was the connection to the ipad (bad cable) -- your input helped me track it to the cable along with another user.  Thanks a million.
2016-9-24
bayguy69
Puerto Rico
btm1008 Posted at 2016-9-24 11:12
Green light on remote is lit -- it was the connection to the ipad (bad cable) -- your input helped ...
Your welcome. Feel free to ask any time. Good flight!
2016-9-24
