Dead gimbal?
3318 23 2016-12-10
fans202792f4
Flight distance : 1502477 ft
My gimbal appears dead after flying once since the recent update. When I boot up my P4P, the camera centers itself horizontally but doesn't do the normal "dance". Also, I have no control over vertical tilt. I've treated rebooting multiple times and refreshing the firmware. Calibrating the gimbal freezes at 5%.
Any ideas?
2016-12-10
airspace_media
Flight distance : 190 ft
Hello I had the exact same issue. I believe this is because one time you started the drone you there wasnt enough ground clearance for the gimbals full range of motion. I tried refreshing firmware and it didnt work. However when I downgraded the previous firmware it was fixed. Give that a go
2016-12-10
fans202792f4
Sadly this didn't help. When I boot up the drone, I can actually hear something happening near the gimbal when it should be doing it's start-up movements.
2016-12-10
DJI-Jamie
Flight distance : 112405 ft
When you enter 'camera view', do you see error message such as 'gimbal disconnected' or does it appear to look fine through the app?
2016-12-10
fans202792f4
DJI-Jamie Posted at 2016-12-10 20:20
No error messages. I can see the camera view.
2016-12-10
DJI-Jamie
fans202792f4 Posted at 2016-12-11 10:29
Would it be possible for you to provide a small video of what you're experiencing?
2016-12-10
fans202792f4
As for what I see on the phone, everything looks normal, I can see what the camera sees, I just can't tilt the camera and the gimbal does not stabilize any movements of the drone.
2016-12-10
DJI Natalia
Please try to touch the gimbal camera with your fingers and check whether it will response or not.
There're no any issues for the flight after firmware upgrading, right? it suddenly cannot finish auto-calibration? have you tried to calibrate it manually?
Please make sure you upgrade it successfully and also you can try to downgrade it if possible then check again.
2016-12-11
fans202792f4
The gimbal doesn't respond to touch or movement at all. It's completely limp. It does not finish auto-calibration. What do you mean by calibrate manually?
2016-12-11
fans202792f4
I think it's fixed. I downgraded to very old firmware and it works. Now upgrading to the most recent.
2016-12-11
fans202792f4
Still having issues. Upgrading to the most recent version failed. Now I'm updating incrementally to the latest firmware. Sometimes when I turn on the drone the gimbal will be stuck in a downward position. I am going to continue upgrading the firmware until I am at the latest version.
2016-12-11
kykphantom
Flight distance : 5892388 ft
Cyprus
I have just exactly the same problem. Only detail which might not has been mentioned is that the camera shows a bit of movement (left-right) - shaking, while at the same time looks dead. Everything happened after last firmware update.
2016-12-12
airspace_media
Guys I did a video on this recently when had issue with p4pro.. As someone else said a temp fix is to downgrade firmware and then upgrade to latest
2016-12-12
nico
Flight distance : 834117 ft
to all off you with gimbal problems...
i am using the latest update.
i got the same problem
this is the solution
switch off the aircraft....
switch off the transmitter
power on... aircraft
and transmitter...
than all is oke
no IMU problem eater
Its ocurs again if you switch first the aircraft and then the transmitter.
First transmitter  than the AC
2016-12-12
fans202792f4
I'm back up to the latest firmware but now I no longer have tripod mode
2016-12-13
airspace_media
fans202792f4 Posted at 2016-12-13 23:12
Bizarre. Which phone/tablet are you using?
2016-12-13
fans202792f4
airspace_media Posted at 2016-12-13 10:10
I'm using the iPhone 7+
2016-12-13
airspace_media
Rumoured to be an issue with new processor chip in IP7 will be fixed eventually
2016-12-14
Coffee
I just inboxed my P4P today for the first time, firmware to latest and I'm getting the exact same problem. I am on an iPhone 6S Plus.
2016-12-14
Coffee
Have you found any resolution OP?
2016-12-14
fans202792f4
No. Currently my gimbal is in a "forced down" position.
2016-12-15
nico
I have got the same problems with phantom 4 pro plus
if it happens than i switch the procedure of switching on...
first RC than AC or reverse...
this will fix the problem
but it is a bug (ver 203)
2016-12-15
Coffee
nico@karssemeij Posted at 2016-12-15 13:36
This does not fix the problem. Try downgrading the firmware through Assistant 2, to firmware ending in .50 it worked for me and I was told by DJI customer support to stay at this FW until they release a fix.
2016-12-15
fans202792f4
Everything is working okay for me so far on the current firmware (after upgrading and downgrading a few times)
2016-12-16
