DJI Natalia
![](https://forum44.djicdn.com/data/attachment/common/c4/common_1_usergroup_icon.png) Administrator
Hi All, sorry for any confusion caused.
To make it clear, if you purchase the Inspire 2 (only aircraft), you can also purchase the license respectively, then activate it.
The reason why you cannot add it to your cart is that it's not available recently on our DJI online store, while it will be available in near future.
Besides, there are three tips for you:
1. You can use it directly if you order the combo from DJI store.
2. If you order aircraft, gimbal camera and license (such as CinemaDNG) together, then you need activate it via Assistant 2 with the verification code.
3. If you order an aircraft only, then purchase the license, you need bind the Cinecore code and activate it via Assistant 2 with the verification code. |
