NDJ6 Controller - S1 switch top position does not work after update.
1780 9 2015-3-15
wpociej
Flight distance : 4020312 ft
Right after updating my Phantom 2 to 3.12 software I've noticed problems with entering the compass calibaration mode (I could only do so after flicking the S1 button up and down for like hundred times) and after a day I realised I can no longer access it at all. After some checking, I've noticed that in Phantom 2 Assistant app the "U" channel does not change it's value when I switch S1 to top (default position), whilst it works in any other position (showing 0 value in the middle and 778 when down). I've tried to dongrade to older software (3.08) but the problem still remained, so I think this clearly points to some hardware related issue. It's pretty serious, as without it I can neither fly in GPS Naza mode nor calibrate the compass.
Since I have a lot of filming to do I'm not keen on sending it to be repaired now unless it's 100% necessary, so hence my question: has anyone exprienced such issue? Any tips? What else can I do prior to claiming repair under warranty? Is there any other way to calibrate the compass (maybe some other combination)?
Also DJI, should the issue remain, please let me know where I could place my warranty claim in Poland other than via my dealer (EURO RTV), as I really need my Phantom up and running as soon as possible.
Thanks in advance for any replies!
2015-3-15
crash1sttime
Flight distance : 1226368 ft
It sounds very much like your switch has failed,
I just pinched this from the PPF forum
These are fairly common SP3T switches (center off) and available in electronic parts shops like Radio Shack or even RC & Hobby Shops. Here's the thread where another PV'er replaced his:
http://www.phantompilots.com/vie ... ;t=4188&p=29296
2015-3-15
oakspi
Did you check the calibration (re-calibration) of the switch (S1) after update?
2015-3-16
wpociej
crash1sttime Posted at 2015-3-16 00:20
Thank you very much for the quick response!
2015-3-16
wpociej
oakspi Posted at 2015-3-17 09:32
Calibration (re-calibaration)? Can the switches be calibrated as well?
2015-3-16
crash1sttime
wpociej Posted at 2015-3-17 13:51
No they can't, not sure what he means
2015-3-16
davidw63
Flight distance : 1096637 ft
You can still hook controller to computer and watch the switch move on the screen to see if they do work properly.
2015-3-17
adrianjacobs
You can initiate the compass calibration from the Vison app, settings menu.. Hope that helps.  Saves wear and tear on the S1 switch too!
2015-3-17
crash1sttime
adrianjacobs@nt Posted at 2015-3-17 19:56
You can initiate the compass calibration from the Vison app, settings menu.. Hope that helps.  Saves ...
He has a P2 so no app
2015-3-17
adrianjacobs
Ah, right
2015-3-17
