rudder control
2115 8 2017-4-26
Struzzinho
Slovenia
Hi boys and girls,
Does anyone know, if unscrewing knobs on controler is the only way to get slower rudder speed?
ty
2017-4-26
kykphantom
Flight distance : 5892388 ft
Cyprus
Go to "Main Controller Settings" then to "Advanced Settings", then to "Sensitivity" and reduce the "Yaw Movement Limit". That's it!
2017-4-26
Struzzinho
Slovenia
kykphantom Posted at 2017-4-26 02:42
thank you for your tip
2017-4-26
Eric13
Flight distance : 15551037 ft
Also: You can get overall much slower and smoother results when flying in "Tripod" mode.
2017-4-26
Struzzinho
Slovenia
I did not find sesitivity in main control settings...but I found "Gain & expo Tuning" also in main control settings under advanced settings and I set rudder L/R on 0.30 that is 0.10 lower than original in normal flight mode (in sport mode rudder L/R is set on 0.50). Do you thik that will work?
2017-4-26
Struzzinho
Slovenia
Eric13 Posted at 2017-4-26 09:43
Thank you will try that
2017-4-26
rparge
Flight distance : 173852 ft
I found this to be a good source for understanding the different settings.
It is for a Mavic, but applies equally to the Phantom.
2017-4-26
DJI-Jamie
Flight distance : 112405 ft
Please let us know if the suggestions provided worked well for you.
2017-4-26
Struzzinho
Slovenia
rparge Posted at 2017-4-26 13:48
https://www.youtube.com/watch?v=iYNcTHF8B3w
It was very usefull cheers
2017-4-26
