Cant disable Fixed Wing Mode
2042 10 2017-6-30
fans1a844320
Flight distance : 181883 ft
Since I set up the fixed wing mode on a Mavic with software 01.03.0900 I can no longer program the C1 and C2 on my remote. Is there a way to disable the Fixed wing mode so that I can use the C1 and C2 buttons again to program the buttons for other uses?
2017-6-30
Lok Mavic
Flight distance : 1486660 ft
I believe you can change it back in the aircraft settings. Click the "..." on the right upper corner, select Remote Controller Settings and scroll down and you will see Button Customization option.
2017-7-1
Marleydawg
Did you have any luck with this issue?? I'm having the same problem
2017-8-24
MARSAN
Flight distance : 966978 ft
You disable Fixed Wing Mode in the same place where you enabled it.
Watch this:
2017-8-25
Marleydawg
Tried that but as soon as I hit the disable button where I turned it on it automatically turns itself back on and I can't customise c1 or c2 anymore
2017-8-25
MARSAN
Marleydawg Posted at 2017-8-25 00:34
When flying your Mavic in Fixed Wing Mode and then pushing the right stick down for a couple of seconds, will your Mavic exit Fixed Wing Mode?
2017-8-25
Marleydawg
Yeah it stops flying in fixed wing mode but is still enabled and asks me to push c1 to engage constantly
2017-8-25
Marleydawg
And can't turn in off In settings
2017-8-25
Ribeiro
Flight distance : 2950994 ft
Removing DJI Go and settings and rebooting then installing it again on iOS resets all the preferences for the flight modes. Did you try it?
2017-8-25
Marleydawg
No I hadn't tried that! And it has worked thank you so much!
2017-8-25
Ribeiro
Glad it worked. Just remember to check you RTH settings, as they were probably reseted as well
2017-8-25
