mY P3p updating prob.
807 9 2017-8-28
bener
Flight distance : 24012 ft
Cyprus
After not usin my P3P for some time (As I was flying my spark recently) I tried to use it today. DJI go asked for update both for RC and craft as well. I uodated my TC well no prob. But when it comes to update my p3p I see its not doing it.i downloaded latest firmware ( P3X_FW_V01.11.0020.bin) copied to sd card as i did before/But when I insert the card in gimble and turn on P3P a red light starts to blink without any beep and its not updating. Normally red and green should blink one after the other.But its not doing it. Why is this happening I dont know. I had updated it before this way and now its not updating. What could be the reason ?
2017-8-28
stuka75
Flight distance : 85682 ft
Wrong forum.This for Standard
2017-8-28
ALABAMA
Flight distance : 10442687 ft
Did you format your sd card before beginning the update?
2017-8-28
bener
Cyprus
ALABAMA Posted at 2017-8-28 16:27
I did .But may be format was wrong. I used another SD card and its updated. This time Rc is not connected to aircraft. I am trying to resolve that too.
2017-8-28
ALABAMA
bener Posted at 2017-8-28 20:19
might try just to relink them
2017-8-29
Peterx
Flight distance : 1499708 ft
Did you format the card in PC card slot or in copters cam? If it was in a PC card slot then the copter may prompt up "invalid SD card".
2017-8-29
Has the issue been figured or not? Please contact us if there is any further questions.
2017-8-30
bener
Cyprus
DJI Susan Posted at 2017-8-30 01:15
Thanks for your interest. Issue is resolved. I managed to connect RC to AC. Now Only issue is max distance issue.I can't make it more than 500 m. so Aircraft max.distance capacity is no use then. Even I buy an inspire 2 it means again ı will be limited with 500 m. with these updates.
2017-8-30
bener Posted at 2017-8-30 22:31
Thanks for keeping us updated. As for the max distance, please make sure the Distance Limit has been disabled and adjust the antenna to confirm the performance.
2017-9-2
bener
Cyprus
DJI Susan Posted at 2017-9-2 00:21
OK thanks. I will try to do it
2017-9-3
