Horizon tilt new spark
2117 8 2017-9-5
djiuser_926gVAR
My spark is only 3 weeks only brand new only 16 flights. I had a gimbel motor overload warning. It stopped but when I got it off the ground the camera was would point straight down. I could move it up with the controls but would go back down. After resetting the spark, the app and the controller the gimbel was working. But I noticed the ground has a slant to it. I got it up 100ft and the entire herizon was slated. I got into the settings and adjusted the gimbel roll to 3.8 to get it straight but notice that the video isn't as stable moving from left to right.
2017-9-5
djiuser_926gVAR
https://youtu.be/yl-5OwjQKa8
Example of the issue
2017-9-5
DJI Elektra
China
Did you try to reboot your spark and see if the warning still here?
I would recommend you check your version of spark.If it is not the latest version, please update your drone first.
Anything news, please tell us. Thanks.
2017-9-5
djiuser_926gVAR
Firmware been updated for the spark, batteries, controller and the App.
2017-9-5
DJI Elektra
China
djiuser_926gVAR Posted at 2017-9-5 18:16
Can you connect app with your drone and provide us a screenshot of the interface?Thanks.
2017-9-5
djiuser_926gVAR
Is this what your looking for
2017-9-5
DJI Elektra
China
djiuser_926gVAR Posted at 2017-9-5 19:30
Did you try to calibrate IMU and compass before you take off your drone?
And you can set your Gimbal adjustment at 0.0 and try to adjust it when it goes wrong.
2017-9-7
djiuser_926gVAR
I have set the gimbel to 0 then calibrated the compass and the IMU (yes with the props off) this photo is with the gimbel set at 0.
2017-9-7
DJI Elektra
djiuser_926gVAR Posted at 2017-9-7 06:46
Please try gimbal adjustment and you can adjust it from the range of +1.5 to -1.5 for most cases.
And then you can see if the image is level or not.
If the problem still exists, I would recommend you contact our support and send your drone back for check. Here is the link:http://www.dji.com/support .Thanks.
2017-9-7
