phlip
Apologies is this is the same problem as stated above, it seems similar but as we are all based in different parts of the world our attempted explanations are perhaps a little different.
Latest firmware has I think been installed to AC but failed on RC.
I now have green light on AC, red arm lights to front and yellow flashing lights to rear arms (which I think is simply the no GPS or calibrate warning) I cannot see the firmware on the AC but think that all is well.
The led next to the link button is alternating green and red with red remaining on for longer than green.
The RC has a red light.
I cannot connect the AC and RC and cannot update the RC
With attempted assistance from tech support I (in theory) reset the units as follows;
AC off RC on
c1,c2,shutter all pressed, switch RC off
AC on, RC on
I then followed the instructions for a forced firmware upgrade to RC;
AC off, RC on
C1,C2, rec, right hand wheel pressed, turn off RC without loosing buttons turn on RC
The RC light is now white/possibly very pale blue
I tried then inserting USB for update but also tried this "reboot" with USB already inserted and also turned off RC and then back on normally with USB inserted. RC came back on with constant Red light and did nothing until it eventually turned itself off.
I attempted to link the AC and RC by using;
AC on - press link button. The red light flashes red.
C1,C2, rec all pressed - switch on RC
C1,C2, rec, wheel - there is a beep and the pale blue / white light but no link to AC
Following the video on page 1 of this thread, after hitting link RC button I get a message asking me to confirm frequency - does this mean the same as the message shown in the video?
I assumed so and clicked ok but the AC and RC still do not link.
If I had wits then I would currently be at the end of them. Your help would be greatly appreciated. |
