(newbie) basic, normal hovering won't work.
778 26 2017-9-18
davidet.
Malta
I am aware of how ridicolous this post might be but for the life of me I can't figure it out. Just using the Mavic for the first time.
I take off from the phone app, the joysticks work properly. up, down, rotation, left, forward, etc..
For some reason the drone never hovers. If I use the 'up' joystick - the drone will keep going up even when not toughing any commands. Only variation to that (altitude-wise) is to pull the joystick down for more than a second, after which the drone will initiate it's landing mode.
I'm pretty sure the drone should hover, stable when idle instead of going up.
What am I doing wrong?
2017-9-18
MARSAN
Flight distance : 966978 ft
Are you flying the Mavic in GPS mode?
If so, how many GPS satellites is the RC connected to?
2017-9-18
davidet.
Malta
Yes I am flying in GPS mode, I am not sure about the number of satellites as I am not able to test is now. Will have a look asap.
2017-9-18
davidet.
Malta
MARSAN Posted at 2017-9-18 11:21
how does the number of satellites affect the ability to hover? it really feels like something stupid from my end. I've tried various locations tens of kilometres apart on different days.
by default, instead of hovering stable when idle it gains altitude. unless it's in landing mode.
2017-9-18
Eagle_Eye
Flight distance : 4137720 ft
Make sure your downward sensors are not obstructed and clean of dust and any particles.
Some B-new 1 have a plastic protection on those sensors,;make sure to remove it and also the front OA sensors.
2017-9-18
davidet.
Malta
Eagle_Eye Posted at 2017-9-18 11:44
Thank you, all sensors are clear from obstruction or plastic films.
2017-9-18
Tmygun
Flight distance : 2972497 ft
davidet. Posted at 2017-9-18 11:47
Did you calibrate the IMU and compass before you took her up?
2017-9-18
Tmygun
Also did you check the sensors page in the DJI App to make sure they are in the green......meaning calibrated properly?
2017-9-18
It almost sounds like throttle stick is slightly stuck, can you do a stick calibration. I.e. RC calibration.
2017-9-18
davidet.
Malta
hallmark007 Posted at 2017-9-18 11:59
will work on all 3 calibrations above. if i recall correctly i did calibrate something. forgot what!
2017-9-18
DroneFlying
Flight distance : 10774613 ft
davidet. Posted at 2017-9-18 12:23
If none of the calibrations fix the problem then upload the flight log (TXT file from your mobile device) to PhantomHelp using these instructions and provide a link to it here and we'll be in a better position to figure out what's happening.
2017-9-18
davidet.
Malta
DroneFlying Posted at 2017-9-18 12:42
thank you. will have a look at everything and post an update.
2017-9-18
Thanks for the replies above, like the users mentioned, please try to calibrate the RC, VPS, and IMU and test again, you can find some tutorials on this page if needed: https://www.youtube.com/channel/UC0sMNc2SGnM-wD3ZGYj3MAQ
Besides, just the verify, is there any error message on the app? If yes, what is that? BTW, please kindly note that the drone will arise to 1.2 meters then hover if you don't touch the sticks when you use auto takeoff.
Please keep us updated if the problem persists, thank you.
2017-9-18
davidet.
Malta
DJI Thor Posted at 2017-9-18 19:10
Hello and thank you.
I have calibrated all the aforementioned. Problem is persisting.
I have quickly put together this video as a visual reference of what is happening:
Is it possible it's some kind of mode or setting?
No errors in the GUI.
Will post the flight log as requested as soon as possible.
2017-9-19
Rushmed
Flight distance : 108081 ft
Had the same problem. Try disabeling VPS and it wil stop auto land .
FW up- and downgrade and IMU calibration did not fix the issue. Mine was repalced,
Have a look at:
This
2017-9-19
davidet. Posted at 2017-9-19 07:26
It looks like you need to send it back, last option is factory reset, but it looks like there is something very wrong there.
Good luck
2017-9-19
It seems like you had mounted third-party accessory on the landing gears, right? Please do not wear it and test again. Thank you.
2017-9-20
DocAraxá
Flight distance : 202283 ft
One  question davidet.,
Why are you not using the side cable?
Cables can bring us some problems, mainly the long one's.
2017-9-20
QuadKid
Flight distance : 482349 ft
Make sure you are not in Fixed Wing Mode.
2017-9-20
fans987d278a
Flight distance : 124180 ft
QuadKid Posted at 2017-9-20 04:18
I'd think if a stick calibration didn't fix her, I'd be calling DJI & get a shipping ticket, send her back or where did you buy it?
Sometimes, the retailer will switch it out for you
2017-9-20
ghostrdr
Flight distance : 1272723 ft
i would take it back if you are still in the return window.
2017-9-20
davidet.
Malta
DJI Thor Posted at 2017-9-20 02:35
With or without makes no difference unfortunately.
2017-9-23
davidet.
Malta
DocAraxá Posted at 2017-9-20 03:46
Sorry DocAraxa, what are side cables please?
2017-9-23
davidet.
Malta
Not in fixed wing mode
2017-9-23
davidet.
Malta
I'm checking into other solutions, namely the returning it back element. There are three main things though: I am posting on behalf of a friend's mavic - that's not mine and she will be making the decision. Secondly is I think they got it a while ago and has been boxed ever since. These last flights have been the only ones the aircraft has ever seen. Thirdly, in Malta I think the only proper DJI reseller is Avantech which I'm not sure handles technical issues and customer support. Will look into this.
Thanks guys.
2017-9-23
DocAraxá
davidet. Posted at 2017-9-23 08:47
Dear davidet,
The cable that comes with the MP and link the controller to your phone.
They are very thin, and they stay at the side of the controller.
2017-9-25
If so, I suggest sending it back and we will take care of it. You can contact the retailer or send an email to support.eu@dji.com. Will do our best to help.
2017-9-27
