Charge both the radio and a battery at the same time?
Stuka
Flight distance : 519177 ft
Can the charger that comes with the dron charge both the radio and a battery at the same time? Is that explained in the manual?
Thx in advance
2017-9-23
Landbo
Flight distance : 502792 ft
Yes, the charger manages both an battery and the RC at the same time. Just go ahead.
Regards Leif.
2017-9-23
allyssongemelli
Flight distance : 2562467 ft
I'm charging both right now. But I have read in manual that they don't recommend to charge both, I don't know why.
2017-9-23
Genghis9
Flight distance : 961 ft
allyssongemelli Posted at 2017-9-23 11:12
Can you please provide me a reference on that manual quote page # and section?
I've looked in mine (P4P) and can't seem to find it or remember seeing it.
2017-9-23
allyssongemelli
I'll try to find. Soon I post here.
It takes a long time charging both, better separate.
2017-9-23
Nigel_
Flight distance : 388642 ft
Genghis9 Posted at 2017-9-23 11:18
It may be just the P4 charger, I think the P4P charger is a little more powerful.
If the charger gets uncomfortably hot then do one at a time, otherwise don't worry!
2017-9-23
Genghis9
Nigel_ Posted at 2017-9-23 11:24
Understood...I think you saw my thread on "hot"
Don't know what uncomfortable is to most, but mine is peaking at about 156 degrees F just charging the batt
2017-9-23
Nigel_
Genghis9 Posted at 2017-9-23 11:26
Normal plastic starts to melt above 90C so that is where I would start to worry, also some capacitors can have problems above 90C.   Your 156F is not a concern.
I think the car charger is more of an issue.
2017-9-23
allyssongemelli
Yeah, better not to overheat above 50 ~60 C. Thats what manual says!
2017-9-23
Genghis9
Nigel_ Posted at 2017-9-23 12:17
Copy that
A) lets hope this is not normal plastic
B) with only a 30 to 40 degree margin not much more room for getting hotter
2017-9-23
I would recommend you to charge the controller and battery separately. Overcurrent may make the charger hot.
2017-9-24
RedHotPoker
Flight distance : 165105 ft
I wanted to have the advantage of charging a battery and my RC at the same time.
To make that convenient, I bought a second OEM 100w charger to help maintain my four intelligent flight packs.
Cuts my charging time in half. I also found a smart way to keep the charger cool when charging.
I place my charger and batteries on top of a double fan that can be tilted upward towards the ceiling.
Works like a charm...
RedHotPoker
2017-9-24
