Laova 7.5mm
2828 8 2017-10-9
giero
Flight distance : 7357333 ft
When will be option to use this kind of lens (manual - without pins) like default lens? I mean - without lens swap process. DJI?
2017-10-9
Giero, sorry that we don't have this kind of information, please pay attention to our website for the future release. Thanks for your understanding.
2017-10-9
Daroga
Flight distance : 3517287 ft
It is being used currently with the I2, check out this video:
You loose any auto capabilities, but further discussions about this lens and its use are available at RCGroups ->
Sample post from RCGROUPS I2 Owners Group
2017-10-12
Mr.Paule
Flight distance : 689442 ft
I would be also very interested ig the LAOWA 7.5mm can be used with Inspire 1 Pro with X5.
2017-10-14
fansa84fe8a4
Flight distance : 3 ft
There needs to be a means to add a non-chipped and/or fully manual lens to the X5 camera series.  Most any MFT camera can allow for this in their menu.  My Olympus MFT has an "Extra Lenses" part where I set the focal length, max. aperture, and a name for the lens and I'm good to go once I select it.  Then the EXIF data gets added to the image and all is well with the world.  DJI has some work to do there, as well as allowing lens version and firmware updates to be done too (BIN update file from lens maker done through the camera menu.).
2017-10-14
flighttime1
Flight distance : 906352 ft
Mr.Paule Posted at 2017-10-14 06:18
Mr.Paule... The Laowa 7.5 works just fine on the Inspire 1/X5. It is a manual lens so there are a few issues.
It doesn't record any exif data and the X5 will produce a file that is unreadable until you correct it with  Opcode Remover (Mac Only) or any other exif data editor.
Obviously you have the limitation of setting the lens before takeoff but I haven't found this to be a problem really. You can pretty much just tape the focus to stay at infinity which will work fine up to any safe distance most would be flying.
2017-10-14
Daroga Posted at 2017-10-12 07:55
https://youtu.be/1cC-j4_NtvE
Though this lens is not in our compatible list, still impressed by the footage.
2017-10-14
martinfueloep
Flight distance : 1551401 ft
Austria
DJI Mindy Posted at 2017-10-14 23:16
Hi Mindy,
I know, that the Laowa 7.5 is not supported, but the lens does work with the X5/R/s, but with the X5R I do have to hotswap it with e.g. the DJI 15mm, otherwise the SSD will not initialize.
It would be really great, if there was an option to use it without hotswapping.
Can you bring this request to your engineers?
Regards, Martin
2018-6-5
martinfueloep Posted at 2018-6-5 00:06
Hi Mindy,
Martin, thanks for your feedback, since this lens is not in our compatible list, there may be some issues, but we will forward it to our engineers for consideration, thanks for your attention.
2018-6-5
