DJI Go 4 V4.2.20 for CrystalSky
12Next >
7777 42 2018-7-9
SubUser
Flight distance : 74140 ft
Hello,
DJI Go 4 V4.2.20 for CrystalSky is out.
Did somebody already do an update ?
Regards.
2018-7-9
UAStelemetry
Where did you find it?
2018-7-9
SubUser
On thread "Jumping compass on CS5.5" #17.
It is maybe not out for Europe ???
Regards
2018-7-9
Chadizzy
SubUser Posted at 2018-7-9 05:13
@djimindy said it was available but its not available in US either.
2018-7-10
Keule
Flight distance : 3733015 ft
It's working - i successfully downloaded and installed GO4 v4.2.20 on my Crystalsky. (Jul 12, 2018 - 20:15 MEST)
2018-7-12
SubUser
Keule Posted at 2018-7-12 10:38
Thank you for the info.
Yes, I could also download it and install it.
It is working ok so far I can see.
I found a new option: if you do a factory reset, it will go back to the previous version .16.
Maybe I was "lucky", maybe you can now always go back to the previous version or at least for a test-period. So I had to install the update again.
DJI should communicate better to us about the things you build in and the fixes you do.
Do we have a rollback option in the factory-reset ?
Regards SubUser
2018-7-12
nixuspix
Flight distance : 2864974 ft
Latvia
To those, who already tested
1. Is the compass still jumping?
2. What about lag?
3. What about choppy video feed and pixelation?
4. If the factory reset is done, only the dji go4 is restored to 4.2.16 and the CS firmware  remains with the latest version, or everything goes back?
5. If the CE to FCC is forced, does the app still offers to change the region or cancel?
Any other issue noticed?
Thanks in advance
2018-7-13
SubUser
nixuspix Posted at 2018-7-13 07:59
1. Like .16, Yes on my CS.
2. Like .16, I could not see any difference.
3. Like .16, I could not see any difference.
4. Only checked dji go4.
5. Yes.
I fly with the OTG and the CS5.5, so far I know there are also two different pieces of software.
So, what is for the CS5.5 could be different for the CS7.8.
And what kind of drone you fly.
I think it is not good to make one general Go4 for every drone type.
If they got a new drone in, we all suffer from the software bugs.
I think they are very busy with the Go4 update for the new mavic...
Regards.
2018-7-13
nixuspix
Latvia
SubUser Posted at 2018-7-13 12:55
Thank You. So nothing to update. Looks like the lag and choppy video  are coming from interaction of Mavic Air 0400 firmware with CS code. Because when tested my both 5.5 CS and 7.85 Ultra CS with the Spark - there is no such problem
2018-7-13
SubUser
nixuspix Posted at 2018-7-13 13:06
Thanks for the info.
Good to know, I was already looking for a Mavic Air.
So, I wait first for a propper update.
Regards.
2018-7-13
fans5b3f5928
Flight distance : 113484 ft
Sweden
Yep, updated but not tested yet, waiting for MavMount to be delivered first.
2018-7-14
nixuspix
Latvia
So what is really good now with CS, that is the CS firmware update is separated from DJI GO4 updates! Thank You DJI !
If you go now in CS settings ( without entering DJI GO4) and ask to check for updates, you'll get the answer, that there are no updates atm.
But if you enter DJI GO4 and there ask for updates, you will be offered to update to 4.2.20. Excellent.
Now DJI has to provide us with access to different DJI GO4 versions to let us select the best version matching our setup
2018-7-14
nixuspix
Latvia
Good as well that i took a plunge and updated CS 7.85" Ultra  from 4.2.16 to 4.2.20. That awful video feed choppy and fragmentation practically gone and i can fly again. Not sure it is the result of matter fixed
by DJI or it was simply the lucky app upgrade. Not sure, but it seems, that compass arrow are jumping a little bit less. The CS firmware version as i told remains the same. And CS keeps FCC mode.
So altogether, for me. it is a very successful update.
Good luck to other fellows!
2018-7-15
SubUser
nixuspix Posted at 2018-7-15 03:18
Hello,
It is good to hear that video feed for your Mavic Air is a lot better.
About the compass :
I did find out that the compass does works better if you keep the monitor horizontal.
So, if I want to know the orientation of the drone I keep CS for a moment horizontal (flat).
It works for me, I hope this will help you too.
Regards and happy flying.
2018-7-15
nixuspix
Latvia
SubUser Posted at 2018-7-15 06:59
Hello,
Thank You for the tip
2018-7-15
Wachtberger
Flight distance : 261509 ft
nixuspix Posted at 2018-7-14 23:19
This is precisely what I had suggested, excellent!
2018-7-15
Wachtberger
Hello,
Thank you for that hint, I shall try it. Still it should work in all positions or have the option to switch off the CS compass.
2018-7-15
Wachtberger
I have just tried to install DJI GO 4 version 4.2.21 manually on the CS, this still does not work. Thus it can only be updated through the app itself which already is a big progress. Now I am curious for the next firmware update which can be expected soon I believe.
2018-7-16
hallmark007
Flight distance : 10186312 ft
Wachtberger Posted at 2018-7-16 05:32
Thanks guys for the tip, just updating now.
2018-7-16
HedgeTrimmer
Followed instructions from other thread (Jumping Compass) and updated to v4.2.20.
No flight test as of moment.  Need to calibrate Compasses.  Check settings.
2018-7-16
Wachtberger
hallmark007 Posted at 2018-7-16 08:20
I had my first flight in the late afternoon and all has worked well. Unfortunately I did not pay attention to the compass, but it has been reported already that there is no change on that side. This doesn't surprise me. It is clearly not an app issue but CS firmware related. I hope they'll manage to fix it with the next firmware for CS.
2018-7-16
hallmark007
Wachtberger Posted at 2018-7-16 11:51
Thank you, will test tomorrow and let you know.
2018-7-16
Wachtberger
hallmark007 Posted at 2018-7-16 11:53
Great, thank you!
2018-7-16
HedgeTrimmer
HedgeTrimmer Posted at 2018-7-16 11:32
Finished re-calibrating compasses and checking settings.
Compass on CrystalSky may be slightly less jumpy.  Because Cs-Ub didn't like initial 1st re-calibration attempt of compass, had to make 2nd attempt.  Something with compass calibration in 2nd part of process it didn't like.
Mavic Pro appears to hover fine, little bit of movement from very slight wind when hovering about 5-feet off ground.  Needs a full flight test.  But wrong place for that.
Plan to re-calibrate both CrystalSky and Mavic Pro compasses in an area where I know there are no sources to cause Magnetic Field Interference.   But that is days away, thanks to a four-letter word.
2018-7-16
SubUser
HedgeTrimmer Posted at 2018-7-16 12:37
I downloaded the version v4.2.21 now.
It says that there is a map-loading improvement ???
You have still to use a external usb keyboard to rename the regio's, the on-screen keyboard is bad.
Compass is still the same...
Somebody is also using this new version v4.2.21?
He Mindy :
New idea.
Maybe use the same calibration procedure like the Phantom:
Horizontal circle, flip the device 90 degree, do a second horizontal circle.
THE DJI DANCE..
It is also more safe, you do not drop your CS by mistake.
Regards.
2018-7-17
nixuspix
Latvia
Excellent DJI!
Finally we have the newest DJI GO4 updates on CS practically together with other Android users. Thank You for this a lot
2018-7-17
nixuspix
Latvia
SubUser Posted at 2018-7-17 03:04
Mate, just go to CS settings, then Language and Input and switch off Autocorrection and You will be able to rename simply from CS
2018-7-17
nixuspix
Latvia
There are mainly positive responses around from 4.2.21 Android users
2018-7-17
SubUser
nixuspix Posted at 2018-7-17 03:42
Hello Nixuspix,
I tried your answer to this matter of the renaming.
But no luck on my CS 5.5, it is not a big deal: I am not flying with the on-screen keyboard.
I do the upload and naming at home of course.
The reason I did mentioned this was:
If it is a bug of a part of the on-screen keyboard program, it is not a big deal.
If it is a bug of a part of the touch-screen programma, it could be a potential a big problem.
(Sometimes I see no response of the touch-screen, I have to press the icon a second time...)
I think for the moment the compass is a bigger issue.
If this was working properly it would be a big improvement to the safety of the flying.
And of course safety is a big thing for DJI.
Anybody knows something about the big release that is a little bit later  ???
Regards
2018-7-17
HedgeTrimmer
Definetly ran into that problem using CrystalSky after upgrades.   Got about half-named typed and it garbled name.
End up re-downloading map and using TLA instead of full name for map.
Keyboard problem is something an intern should be able to fix.
2018-7-17
HedgeTrimmer
SubUser Posted at 2018-7-17 07:10
Hello Nixuspix,
Often takes several ''touches'' to get CrystalSky UltraBright touch screen to take input - anytime the touch input is near the edges, worst being near corners.
2018-7-17
Anthony566
Flight distance : 2488944 ft
Had a flight this week and the video feed was very choppy ...  I am trying to download 01.04.0400 atm but the download keeps failing
2018-7-17
Wachtberger
nixuspix Posted at 2018-7-17 03:28
Excellent DJI!
Yes, this is a great improvement indeed! Just updating to .21 :-)
2018-7-18
Anthony566
Updated to .21  last week and have had 6 + long flights and all seems to be working OK flight wise, still some chop in the video feed. Not sure about the compass as I don't really use it.
2018-7-30
KEKA
Flight distance : 5535 ft
Hola, me podeis ayudar ?.
Tengo un Crystalky de 5,5 "donde tengo que buscar para la actualización DJI GO4 en Español,
2018-8-23
KEKA
Hola a todos.
No hay nadie en este foro que me pueda ayudar ni la empresa misma DJI.
Saludos...
Gracias
2018-8-25
SubUser
KEKA Posted at 2018-8-25 04:13
Hola a todos.
Saludos...
Hola,
Creo que es mejor que hagas tu pregunta en inglés.
La actualización de CS llegará automáticamente a su CS, solo tiene que instruir para que se realice la actualización. Supongo que ha elegido el idioma español en las opciones.
Con saludos amistosos.
2018-8-26
KEKA
Hello, thank you very much for your comment.
I have installed the version dji go 4 v4.2.21 in my CS but it is not in Spanish
How do I change the language?
Thank you so much
2018-8-27
djiuser_drone
Hi Dji members,
Has anyone heard of date rumor date as to when Dji will release a firmware for the CrystalSky monitor that will work with the Mavic 2 Pro and Zoom?
I'getting this error trying to activate the Mavic 2 Pro
2018-8-30
KEKA
Thank you so much
2018-9-12
12Next >
