RESET DJI MINI 2
49349 19 2020-12-18
Thomaz
Flight distance : 3579560 ft
Brazil
I would like to know how to reset the dji mini 2?   att Thomaz
2020-12-18
Thomaz
Brazil
2020-12-18
Montfrooij
Flight distance : 2913035 ft
What do you mean with reset?
2020-12-22
Thomaz
Brazil
Montfrooij Posted at 12-22 01:18
Good afternoon! I want to go back to the original factory settings, the firmware and all the settings, after updating to the latest update, this is giving error 40011, gimbal error.
2020-12-23
Thomaz
Brazil
Thomaz Posted at 12-23 13:55
but this is working normally, I have recalibrated automatically and manually with 100% success and this error continues on the screen
2020-12-23
Montfrooij
Thomaz Posted at 12-23 14:01
Ok.
That is not as expected.
I don't know if you can get back to another firmware. (older)
Maybe try in the 'products' section of this forum.
That is way more active!
2020-12-23
Thomaz
Brazil
Montfrooij Posted at 12-23 14:06
Ok.
There is nothing about it, the dji assistent consumer doesn't only work for downloading a file, it's not the same as the mavic mini, why is that?
2020-12-23
Montfrooij
Thomaz Posted at 12-23 14:10
I have no idea.
My suggestion would be to try and ask this in the 'products' section of this forum.
You are now in the 'tutorials and tips' section.
There are more users active on the 'products' section.
2020-12-24
DJI Stephen
Hello there Thomaz. I am sorry for the trouble this has caused and thank you for reaching out.  Since you are getting and error message ( 40011 ) on the the DJI Fly application did the said DJI drone ever encounter and hard landing or a crash before? Please try to restart the drone and refresh the firmware of the said DJI drone then calibrate the gimbal to see if the issue will still persist. If the issue persists, I would recommend for you to contact our DJI Support Team at https://repair.dji.com/repair/index?site=brandsite&from=nav for further assistance. Thank you.
2020-12-24
fans161971e1
Mexico
Hello Thomas, I have a issue with the update of my dji mini2, yesterday I update the control, but at this time, the dji assistant 2 is asking me restart the device for restore, I don’t know why isn’t connection with the camera, but actually can fly and is working perfect, but no image and no connection in the app between the air craft and the app. Please help.
2021-2-3
djiuser_R75g9x5WTfUU
Flight distance : 258825 ft
Philippines
Would be glad if there would be an option to clear the errors
2021-2-6
urbann91
Flight distance : 1081818 ft
Russia
Did you fix error 40011? The same thing happened after the update to v.01.03.0000
2021-6-16
djiuser_zqacGPRZ8OS3
Buenas tardes,. A mi me pasa algo parecido, tuve un accidente con el dron y  a la vuelta para poder volarlo me da error de sistema de navegación y no puedo volar el dron, aparentemente no tiene nada dañado, cómo puedo quitar ese error?, Gracias.
2021-8-28
PAAZ
Guatemala
djiuser_zqacGPRZ8OS3 Posted at 2021-8-28 10:42
Puede que se haya roto un flex que conecta el dron con imu y gimbal.
2022-1-29
djiuser_jItT84tJzHTU
Brazil
Bom dia, meu mini 2 acusa ininterruptamente sinal fraco e as vezes
em voo, desconectando a aeronave. Wue pode ser isto?
2022-5-28
Afranio Souza
Brazil
Meu controle DJI mini2 parou de funcionar do nada, alguem consegue me ajudar?
2023-4-20
marcelo quenio
Brazil
Meu dji mini 2 se pede pra calibrar o controle aí calibro ligo o drone e ele pedi pra calibrar de novo. O que pode ser está aparecendo erro code 60010
2023-5-7
djiuser_x8voAZdI6k7G
Flight distance : 6663 ft
I have a mini two, and when I go to lunch, the motors didn’t have a whole lot of power and it doesn’t take off.. And then when I restart it, it takes up fine. What could be the problem with it ?thank you in advance.
2023-5-8
joao marcelo
Panama
Boa noite Tomaz meu DJI 2 fala que o aircraft está desconectado o que devo fazer o drone não me dá imagem e nem vídeo, o que devo fazer ?
2024-2-26
DJI Gamora
joao marcelo Posted at 2-26 17:37
Hi, joao marcelo. Thank you for reaching out. Can you please confirm if the message appears during the flight or before taking off? We will wait for your reply.
2024-2-27
