Mike 904
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
Flight distance : 3871 ft
So I contacted DJI Support. Here is the correspondence:
Subject: No 5.8 wifi channels, only 2-10 on 2.4
Message: Recently received Mavic Air. No 5.8 options available. Only 2-10 on 2.4 (my understanding is 2.4 should at least show 1-11). Very limited range. Have all the latest firmware updates via DJI Assistant 2. iPhone 6. Also, noticed the date format on flight records is in the format day/month/year. Screen shots of firmware, wifi, and flight records attached.
Dear Michael,
Good day!
Thank you for contacting DJI Technical Support. We thank you as well for providing us the screenshots for us to rectify the issue. We would like to apologize for the inconvenience this has caused you and we will do our best to assist you as soon as possible.
For your concern, you can change it by changing the channel you use. if you go into the wifi settings in the app, it will by default choose what it thinks is the best signal, since 2.4 is generally more powerful, it will usually default to that. However, if you choose "custom" and scroll down to "Channel Index" you can chose different channels, and depending on the one you chose, will choose 5.8 or 2.4
We look forward to hearing from you soon.
Thank you and have a nice day.
Best regards,
Limwel
Website http://www.dji.com/support |
