mavic pro remote controller calibration problem
1657 2 2017-6-23
fans33ad00a6
hello,
this week i have received my new mavic pro.
After i have unboxed it i have noticed a problem with the remote controller when i run the calibration process.
in detail, after press the calibration button, the number on the right of the left stick is always set to 9/10 (rather then zero)
and when i do the calibration process the maximum excursion of the left stick on the left upper/lower corner is 90 (rather the zero)
i have updated the firmware to the newest version (1.3.900) uninstalled and then reinstall the dji app on my phone, but nothing change.
sometimes the application show me a warning like "Strong interferences", but it's impossible, because i retried the calibration many times on different places.
I can finish the calibration process but the number on the right of the left stick is still set to 9
can be a hardware issue?
anyone can help me?
thanks
Alessandro
2017-6-23
fansd4d9fa67
I am going through the same thing right now. I have not found a fix yet mine is on the left stick and will sit at 7%to the left.
2017-6-25
fansc3f19f46
Did you ever get a fix to your issue?  I have a lot of trouble getting my controller calibrated before it times out. Instead of following the ball around the track you have to try and push mine around.
2018-3-4
