Cetacean
Flight distance : 2528264 ft
Aloha Emilio,
Well the DJI GO 4 waypoints mode do not allow negative waypoints. I tried repeatedly and got nowhere. The only way to get negative waypoints, that I have not tried yet, is to fly to the lowest point and land (and shut off the motors). Then with the restart, a new Home Point will be set and waypoints should be possible from there because they will be positive.
I will try this two ways. The way I just described is one and doing a restart from higher up and then coming back to my normal flying area is another, and safer, one. If I can set negative waypoints like that then there may be another option. I already have landing pads set higher up so this will also be the easier test.
I will get back to you later on this. Always like another excuse for a new test!
Aloha and Drone On! |
