Spark from the sky
1776 12 2017-7-1
SaintPaul
Day 3 of my new Spark, took for a fly today.
Battery was full, using the remote controller in normal mode.  I was in a nice open area.
I flew it up to a height of 67m and it was about 30m away.  I was showing a mate and the motors could still be heard.
Just hovering in place and I was about to take a photo.  Suddenly I couldn't hear the motors and I looked up and down it was falling.
Battery was full and had good signal strength and GPS signal.  The motors just stopped.  Wasnt touching any of the sticks or anything.
Amazingly it had no physical damage to the motor arms or the gimbal or camera. However.....
Sadly it now has 4 red LEDs and errors in the app saying navigation errors and unable to fly.
Now waiting for a reply from DJI to my email and how to send them the flight logs.
Only 37m of flight time total
2017-7-1
fansdf9f8924
Flight distance : 80951 ft
I was just out flying mine only had it a few days as well and it was about 4 m up and 20 away and it also just fell out the sky!!! Battery was at 50 % and when I picked it up the spark was completely switched off . I powered it back on and it came up with a low battery message still saying there was 25% . I was lucky as there was no damage a part from to my confidence in the spark .
2017-7-2
SaintPaul
When I took off I had a fully charged battery and the flight only lasted 1min 22 secs or so.
When I turned the drone back on it said it still had 90% battery life
2017-7-2
jN3Gxz6w6vIq
Flight distance : 5538 ft
Same thing just happened to my Spark, fully charged battery in the air for maybe 3 minutes using RC, and totally cut off and fell from the sky. Lucky I wasn't high and it fell onto soft ground, no damage, but in the process of sending the logs and demanding a refund as I now have zero confidence in the safety of this drone.
2017-7-2
SaintPaul
Sounds like the Go Pro Karma all over again
2017-7-2
jN3Gxz6w6vIq
jN3Gxz6w6vIq Posted at 2017-7-2 16:59
here's the link to my black box data: https://www.dropbox.com/s/hsxs2z ... lack%20Box.zip?dl=0
2017-7-3
fansfa02e076
Flight distance : 1538845 ft
Same thing happened to me but over a lake. Unable to retrieve drone. Who do we contact at DJI to check the logs and possibly warranty?
2017-7-3
Szwedu
Flight distance : 378114 ft
Poland
No aircraft no warranty...sry
2017-7-3
BriRi
Szwedu Posted at 2017-7-3 14:09
Incorrect ^.... No aircraft = no Refresh.... Warranty CAN/WILL replace after reviewing my logs.... many others have had replacement in this situation.... Just need to know which DJI customer service/repair/other to open my case with.
Anyone?
2017-7-3
Feiyau.lim
Flight distance : 398274 ft
Malaysia
had a similar situation few days ago but luckily managed to recover it. It just descended quickly after disconnected with no warnings about 70m away at height of 60m. Sent logs to DJi awaiting feedback.  https://dji.zendesk.com/hc/requests/610972
2017-7-3
QHovey
Question to everyone who's seemingly had the battery indicator lie to them, was it a new battery?
I'm not an expert in what kind of battery tech DJI is using, but some systems need a full cycle to calibrate the battery sensors. I know DJI ships batteries in hibernation mode, and requests that you fully charge them before use. This sounds like a calibration system. If it's not the first flight, then maybe the calibration got totally jacked, and the indicator started lying. If it was the first flight, then DJI needs to figure out a way to correct the initial charge calibration system so that it isnt dropping drones out of the sky.
2017-7-3
SaintPaul
Hopefully this works and is the right data.  It doesn't seem to show alot about the crash though.  One minute its at 69m and then nothing
http://app.airdata.com/main?share=LuSxub
2017-7-3
BriRi
QHovey Posted at 2017-7-3 16:16
It's not the indicator. It seems to be battery failure which shuts off all 4 engines.
My battery was a new one that I ordered from Advexure. It was 3 minutes into its third flight when it appears to have shut off. I have 5 batteries and hadn't had any issues up until this flight.
2017-7-3
