Punchbuggy
Flight distance : 483166 ft
Hi. Geebax's advice is brilliant. I'd add to that by suggesting that you buy a 64Gb SD card to replace the standard 16GB card. It's a good investment to give you more recording headroom, as the 16Gb card doesn't go far if you're recording videos in full Ultra 4K, for example. But make sure you buy a card of the right spec - the ones I bought are the Samsung 64GB EVO plus UHS-I Class 10 Memory Card, but there are numerous other brands.
And after each flight, get into the habit of downloading your files to your PC for post-processing, and then re-format the card on the P4P as part of your pre-flight actions.
Also, set your app video cache to a reasonable size (I set mine to 8Gb, with 'auto overwrite') to keep a reasonable store of your in-flight video stream. It's those videos which the DJI GO app Editor uses to create nice little videos on-the-fly. The Editor by default doesn't access the full-quality videos stored on the P4P itself.
