Other Issue .....
675 3 2017-7-11
Zerohack
Flight distance : 152566 ft
When i connect the Spark with usb cable on PC  and Assistant 2 is running, the internal cooling fan does not work. In a short time the temperature becomes very high. I turn it off and than i turn it on again but the Spark switch off automatically . I think the temperature probe switches it off.
I must wait five minutes for turn it on again.
2017-7-11
Dirk52
Flight distance : 318123 ft
Does the fan run when you are not connected to the pc?
If not then you have to send it back.
A shut down during flight wouldn’t be great.
2017-7-11
Zerohack
The fun run when the spark is not connect to pc.In P4 the fan work every time.
2017-7-11
Dirk52
Zerohack Posted at 2017-7-11 07:56
The fan of my spark runs also when not connected to the pc.
Really strange.
2017-7-11
