Kmelx Posted at 2017-7-17 23:13
You need to plug a phone or tablet signed into the DJI Go APP and get the drone to go fly before every goggles flight, to remove the beginner mode flight restriction which is limiting your flights, then you can unplug the tablet and plug in the goggles and fly it as normal without the beginner mode restrictions.
It's a consequence of DJI's last firmware update which means you have to be signed in to the app to use the drone out of beginner mode, unfortunately or perhaps fortunately given how unstable the GO APP can be, the goggles do not seem to run the full app or if it does it doesn't lift the flight restriction, so the drone is stuck in beginner mode if you don't connect something which is signed into the app first.
I understand this issue and why it is happening and what must be done to make things work. However, besides all the problems of FW updates etc. I am most bothered by this recent change. It means many added burdens to the end user if they wish to operate their own property in a responsible way yet in a way that they choose. I have seen many questions asked about this requirement but no official answers for them. Such as, what if I'm out in a wilderness area far from any WI-FI or cell signal, will my aircraft be limited simply because it can't call home (BTW whose home, my property stays at my home not DJI's home). I am continuing to assume that the reason DJI decided to take this drastic step is due to liability concerns, but I feel that a reason such as that is a stretch. There may be several other reasons for it; I will avoid opening that can of worms, as it is only speculation. What would be tremendously good is if DJI rethought this requirement and came up with a way for folks to either opt out or apply a check mark accepting full liability for any actions they take when using their bought and paid for property. DJI must find some kind of happy balance between their need for control and our right to use our property freely. Just as importantly, a way for all of these great products to start working easily with each other without having to jump through our spandex buttholes to make it happen…hopefully, I’m not asking for too much. I’ll step off my soapbox now…thank you for your indulgence.
