Spark qr code error!!
2468 7 2017-7-29
GuArDiYaNsS
Turkey
Hello my new family. I got dji spark 4 days ago. I can connect the device to the dji go application and fly it. But it does not recognize the code on the box and the code on the device battle. When I click on "scan qr code" in dj go 4 application does not recognize the code? Said the service did not need to call. Is it important to introduce the code?
2017-7-29
hallmark007
Flight distance : 9827923 ft
QR is not working for everyone, you may have to do it manually.
2017-7-29
GuArDiYaNsS
Turkey
Where is the manual done? I couldnt find it
2017-7-29
Didiko
Flight distance : 18399 ft
Belgium
GuArDiYaNsS Posted at 2017-7-29 11:36
When you launch the DJI GO application for the first time, you have to "declare" the drone to the software. This is done by either scanning the QR code on the frame under the battery compartment (but this can indeed be hard to do with some smartphone cameras), either enter it manually into the software.
2017-7-29
GuArDiYaNsS
Turkey
Initially I started by connecting with wi-fi. But the camera can not verify the code in the scan. Where can I write manually? I could not find the manual menu
2017-7-29
GuArDiYaNsS
Turkey
Where do it manually
2017-7-29
GuArDiYaNsS, please check the following tutorial video for your reference:
2017-7-30
GuArDiYaNsS
Turkey
thanks administrator. i see. but  dji go 4  can not find it when I scan the code.The code could not be found errors. where  I can manually record ? now  running smoothly. Do I have to register with the code?
2017-7-31
