WPONPAI
Flight distance : 99590 ft
DroneFlying Posted at 2017-8-4 05:10
It looks like your left front motor stopped providing propulsion at around 2:37, and from there the data shows just what you described and what you'd expect given the loss of that motor: the Mavic began to yaw / rotate counterclockwise and pitched forward until it literally flipped and crashed. It looks like there were a couple of impact events, one about a second after the motor loss (hitting the bushes?) and another a second or two later (presumably hitting the ground).
One interesting and possibly relevant fact is that same motor was running noticeably (e.g., 5°C) cooler than the others pretty much the entire flight. Offhand I'd suspect some sort of defect that should be covered under warranty, but a physical examination of that left front motor is what's really needed for a definitive analysis. Good luck and please let us know how it turns out.
Thanks for the analysis I hope to be in warranty. |
