I updated the firmware in my controller for my P4 and as soon as I did I recieved an error message saying: "Current DJI device: Inspire 1. Download DJI Go for this DJI device."
I cannot see the firmware im using as I cannot access anything on the DJI GO 4 app. I have tried redownloading the app, using a different device with the controller and using DJI assistant with no luck. Any ideas?
Thanks.
I would recommend you to link RC without the APP, then connect the APP again.
a. Turn on both the aircraft and the controller. Hold C1, C2, and the record button (top left button) on the controller.
b. Then press the wheel on the right side of the controller
c. Use a tool to click the linking button on the aircraft and hold for 2 seconds to link.
Just to verify, the linking RC without APP is successful, but the same issue appeared when connected via DJI GO, right? Which mobile device have you tried?
H. I have the same problem. I have made an update. since the blinks the copter yellow and get the same message. the remote control is lit solid blue or white. the remote control has turned on the first press on the one button. the key combinations c1 and c2 ..... can not be executed. the remote control remains in this condition. I would be glad about any help. Greetings Stefan
JesseStLouis Posted at 2017-10-29 10:04
Any idea how long it takes to get a repair done or returned? Its been almost a month and I haven't heard anything yet!!!
CAS-1072914-Y0B4V3
Sincerely sorry for the inconvenience. I have forwarded this to the designated team to expedite the progress, and they will take care of this case and keep follow up for you. Hopefully we can figure it out soon.
DJI Susan Posted at 2017-10-30 00:30
Hello friend, did you get your Phantom 4? Mine gave me the same problem
The Solution:
1. From the market install the DJI GO from drone BEFORE P4.
2. In the PHOTE/SETTING/APPS reset the DJI GO and the DJI GO 4 apps defaults.
3. Turn off the RC, make sure it connected to you phone and turn it back on
4. The phone will ask you which app to choose DJI GO or DJI GO 4 choose DJI GO
5. When the app is up make sure the chosen device is inspire 1
6. Wait 3 sec and long click on the menu at the upper right corner.
7. In the downloading firmware to select the version 1.5.80 and install it.
8. Disconnect the RC USB and turn on your drone P4
9. Connect the RC to your phone again and it will tell you now that this is a P4 remote and will ask you to use the DJI PRO 4 – load this app.
10. The DJI PRO 4 will ask you to upgrade your RC – upgrade it.
11. Now the RC is working again and you will be able to fly.
