fans4e88ec63
Flight distance : 466965 ft
This thread is aimed for all of you to comment on what you think is needed to work on the Phantom 4 Pro Plus Controller.
I had some good expectations when I purchased the P4P+, however I need to say it has been a disappointment so far, hence I feel I need to raise a flag so DJI can help and put some work into it.
1) Display is Great!! Probably the only good thing about the controller
2) Unable to plug another device - This was a huge disappointment as this should be pretty standard, If for some reason the screen is damaged the whole controller is useless, with the normal controller, change the device and you are good to go.
3) Android, I need to say that I am not big Android fan, however the fact that the P4P+ controller has what I will say 10% of Android functionalities makes it even WORST.
- - No possibility to install other apps
- - Incomplete android menus
- - it is very unstable, the flight and video player is extremely slow and if you want to scroll in the video couple of times the app will stop responding
4) Firmware update is a nightmare, First it is stated that the firmware must be done via the microSD Card. (come on!!) imaging having to install an SD Card to install a new iOS or Android Version
- - Even if done via the microSD Card, I phased the fact that DJI does not keep up the webpage with the latest firmware, all of sudden a new version is requested but the new version is not available in the DJI webpage to download.
- - Not clear if over the air updates can be done. If that is the case, why state that the firmware update must be done via the microSD Card.
5) Suddenly and with no reason the WIFI gets disabled, Need to swipe down to find the menu of WIFI and turn it on. (not intuitive)
6) Suddenly and with no reason the GPS gets disabled (the GPS from the controller). I was lucky that a menu pop-up to enable it back, again it should not have been disable on its own to start with.
- - I have tried to find the GPS (Controller GPS) enable disable within the + Controller menus (Inside DJI GO 4) or in the Controller system Menus and I have not been able to find it. So, if something happens to that I wont know where to activate it back.
7) Sound Recording: Randomly records or not the sound via the MIC on the controller, It has happened few times to me already that in post view there is no sound and re-check the option to record sound is active, so this seems to be completely random.
8) Unable to update firmware from Assistant 2. You will think that if so important to update the firmware, the minimum should be possible is to be able to do it from the assistant 2, but no, the assistant 2 does not show the firmware update for the P4P+ controller.
9) DJI Go4 app updates. Not clear how the DJI go4 updates happens, One thing is the firmware of the device and another the version of the App, but seems that for every new version of the App a new firmware update is needed. this is completely non-sense.
10) Chinese language appears from time to time. I have nothing against Chinese language, but if English or other language is selected, all the things should appear in the selected language. But no, randomly some Chinese appears from time to time.
11) Update NFZ, (No Fly Zones), I am not sure if this is only a P4P+ issue or general issue, but there should be a place where it is checked that the NFZ are checked to be the latest (just like the firmware check).
In summary, My experience with the Phantom 4 Pro Plus controller has not been good at all. I really hope DJI puts some work into it to improve it. In the end we have paid a premium price for it and it is much less capable of using a normal mobile.
If you do know how to fix or resolve some of the points I included Above, please feel free to comment, or also if you have other issues, please highlight them so the users will be aware and also DJI can have the proper visibility.
