fanta78
Flight distance : 74577 ft
Denmark
Hi Montfrooij,
You were right !!!
I checked the source file details with VLC and it told my the coding rate is 29.970034.
So I build up again the project at 29.97 frame rate. But guess what ? I got the same 'travelling glitch'.
I tried dozens of settings and codec, and fps from 24 to 30... no success. Until I found out that the sequence in which my source files are ordered was set up to 25fps.
This visibly overrides the global project and export settings.
So I change the sequence settings, I build again the project and now the result is similar to the original file, perfect ! Thanks again for pointing me in the right direction
Piloting the Spark is easy. Building a nice and smooth video after that, this is the real challenge
I'll post the result tomorrow. |
