DPirkl
Nigel_ Posted at 2017-9-17 00:41
I don't know why everyone is blaming the pilot!
The Phantom should reject any command that would cause it to flip and protect itself, also if it does flip for some reason then it should flip itself back and return to normal flight. There are videos showing the P4 can recover from being upside down very quickly.
it did not hit anything, it was in the air clear of everything,,, nothing but blue sky in view. I have also heard that maybe the battery disconnect or I could have performed the Kill sequence. what I cannot remember is if the drone propellers were spinning while inverted and heading to the ground as it happened so fast. I feel that they were still spinning but I cannot be sure.
As to the logs, I have the entire DJI_Record folder moved over to my laptop but not sure how to upload it. I will tell you that the txt files don't look like anything readable. maybe someone can make sense of it if I can find out how to upload it here. I guess I could put it in Dropbox and share the folder? |
