What is the right sequence?
allyssongemelli
Flight distance : 2562467 ft
Brazil
Hey, I'm getting confused what is the real sequence to turn and connect the drone. Can help me?
- App DJI GO turn
- USB cable RC to smartphone
- Turn RC
- Turn AC
Is this correct to get connect right the AC?
2017-9-23
Genghis9
Flight distance : 961 ft
Are you asking?
-Launch the DJI GO App - Open it
then
- connect the USB cable to the RC & smartphone
Then
- Turn On the RC
then
- Turn on the AC
Yes that sounds OK to me and is similar to how I do mine.  The manual does recommend a sequence but it is not clear, can be found on pg 57
2017-9-23
allyssongemelli
Brazil
Ok thanks . Sonetimes i was open the app after turning the RC
2017-9-23
Mark The Droner
Flight distance : 2917 ft
Here's how I do it with my P3P:
Make sure cable is not connected to mobile device
Turn on controller
Turn on mobile device
Turn on AC
Wait.
After mobile device has booted up and I have swiped the screen and "logged on"...
Plug cable into usb port of mobile device (I use Android) (other end is already plugged into controller).
I get a pop up that asks me how or with what app do I want to use the usb port?  One of the options is Go so I touch that.
Once or Every time?  I choose Once
Then I bring up the Go App
I'm all set.
I'm sure there will be others who will have different opinions.
2017-9-23
Teckoldt
Flight distance : 231014 ft
South Africa
That sounds good, the most important thing about that is the arc must be powered up before the aircraft.
2017-9-23
allyssongemelli
Brazil
Yes, this is automatic in my mind, at least hehe
2017-9-23
RicardoGray
Flight distance : 4356421 ft
Mark The Droner Posted at 2017-9-23 11:42
I follow Mark's procedure too. Never had an issue.
2017-9-23
hallmark007
Flight distance : 10017858 ft
Remember when turning off.
Opposite
Turn off AC
Turn off RC
Turn off App
2017-10-3
allyssongemelli
Brazil
Yeah, thanks
2017-10-3
Landbo
Flight distance : 502792 ft
Denmark
I almost do the opposite.
1. Turns the tablet on and connects the RC USB port to my tablets USB port.
2. Turns on RadioController.
3. Turns on Mavic or Phantom.
and then DJIGO4 pops up and asks to use the USB plug on my Android tablet, which I naturally allow.
In fact, it does not matter if DJIGO4 has started up or it crashing as it is your RC you control the aircraft with.
Fly safe, regards Leif.
2017-10-3
allyssongemelli
Brazil
I tried as same of you Landbo, but my app pop up right when I open it after turning on the RC and AC.
2017-10-3
