Nigel_
Flight distance : 388642 ft
nikitapiankov Posted at 2017-9-28 08:16
Ok, you say that P4 is limited to 36kph (20mph) in Track mode, but you had wind of 43 and it also managed to move a bit. So it must have had air speed of about 50kph? Do you have the newer P4 or the standard?
Too bad their P4 page with specs is gone. You can buy it (refurbished), but I can't find the official specs!!!
You can download the P4 manual still, it was updated not long ago, I guess you will find the specs in there.
Yes, I think max air speed of 46kph in active track, but only if it is windy, following a windsurfer max is presumably 36kph since the windsurfer is never going to sail straight into the wind!
76kph in sports mode even without wind, although I don't think I would want to be the pilot trying to film a windsurfer at that speed!
Mine is a standard P4, for most purposes perfectly adequate.
In wind over 40kph I would be a bit worried about it getting salt spray inside, very bad for electronic circuits.
