Bug that causes motors to stop during flight
506 0 2017-9-29
Kzone
Sri Lanka
Hello!
This porbably will not occur during flight but there is a possibility, therefore I would like to consult you guys!
During flight if the drone is blown up then there is a possibility for the motors to stop. This can be recreated easily, when the mavic is hovering a feet or two above the ground gently push the drone up using your finger. As it is lifting you will notice that the propellers slow down to maintain stability. If it slows down too much the drone will immediately kill all motors causing the drone to fall.
If attempting this I would highly advice you to do so on a bed or any other kind of soft surface.
Thoughts?
-Kzone
2017-9-29
