Zuidwestdrones
Flight distance : 276604 ft
Belgium
fans25ad1327 Posted at 2018-1-24 08:17
Thank you BigredsX13 and everyone for commenting. BigredsX13, we did figure out how to change between the apps in the Crystal Sky, after a while, but thank you for sharing that and I'm sure that information was very helpful for anyone else using the 210s and reading this post. We still don't have flight logs while using the Pilot App. We get flight logs in Go 4, but as you said, they are 2 different apps. We did some more testing last night with all our gimbals and the 210s. We found out that you can only use Go 4 with the 210s when you have the HD camera only (such as X4s or X5s). If you have the XT FLIR on either by its self or on the dual set up with an HD camera, you cannot use Go 4 at all, you must use Pilot anytime you have the XT on. This creates issues for us becuase we don't have flight logs, AND we cannot access our special airspace unlocks in Pilot, only in Go 4. DJI unlocked airspace for us once we showed our 107 airspace waiver but you have to use Go 4 or Go to access the "Unlimit Area" feature, its not in Pilot yet. Also, there is an XT Pro App which is what is best to use with the XT FLIR I understand, however this app is only available on IOS and not Android yet, therefore we can't use it on our Crystal Sky monitors. I really hope DJI figures this stuff out soon. We invested over $30k into these platforms and are not happy at all unfortunately. Thanks everyone
Hi
You can use XT with dual downward gimbal and DJI GO 4 app. You have to mount only the XT and let the other port without camera. Then you can start the DJI Go 4 app. It will say you have to use Pilot app, but you can use GO 4 app. Only one thing you don't have with GO 4 and XT: you don't have temperature on the screen, you can only see the different colours of you camera. I did test this today, so I know this works.
What I did not test is getting the flight log with this solution, but I think you get them, because you use the GO 4 app.
Today, I did some more testing. You can read them on:
https://forum.dji.com/forum.php?mod=viewthread&tid=115035
and a very interesting test was this one:
https://forum.dji.com/thread-131094-1-1.html |
