TranceMist
Flight distance : 1661591 ft
Gunship9 Posted at 2017-10-25 06:56
That is why I bought a third battery. You can't get one battery ahead on the charging, while you fly the others, since they wait for each other. I guess the tray switches to cell balancing/trickle for all bays, when battery is full-ish, so the batteries have to arrive at that level together.
This is why I bought a second multi charger. The power supply is limited to 50W and adding a 3rd battery really slows things down.
As other have already said though, be patient. After a few minutes you'll see that the battery that stopped charging will resume. I presume that the multi charger is trying to balance the limited wattage that it has across the batteries and when you plug a new one in it first tries to determine the need of that battery.
Not an ideal design for sure, but it does work. |
