Ground stasion connect!!! HELP!!!!!!!
2121 10 2015-4-11
gherewith
Lithuania
Hey, I need to connect my dji phantom 2 vision to ground stasion. How??? How connect it like android? ( without any of that stupid think ) How make just connect ( 2.5Ghz ) wifi ( like android ) to controler and use ground stasion? Also how use joistic to play HELI-X?
P.s. i think i never agen buy dji products.. terible support...
2015-4-11
nig_smith
I think you might be confused about the App for the Vision and the App for the Datalink Groundstation. The latter is for the separate Datalink hardware that uses either 2.4GHz or 900MHz. The RF connection does not use a WiFi protocol instead the iPad connects to the ground Tranceiver unit via a Bluetooth link. The ground unit then connects to a separate  transceiver on the craft to convey telemetry and receive the mission waypoints.
Regards
Nidge
2015-4-12
Raybro
Flight distance : 11099 ft
Are you talking about the P2 Vision+ or 2.4 MHz datalink? The datalink will only work on a PC or IPad rev 3 or later.
2015-4-12
gherewith
Lithuania
I hawe P2 Vision ( not + ) . How i can control it direct from pc ground stasion ( without datalink,......etc ). I can control it only from android phone ground stasion? ( its work ) but android to small screan so i need control it from loptop ( i buy loptop for that ). I connect my loptop via wifi to my DJI P2 controler and its steal invizible in ground stasion software..
2015-4-13
gherewith
Lithuania
nig_smith@o2.co Posted at 2015-4-12 17:53
I think you might be confused about the App for the Vision and the App for the Datalink Groundstatio ...
Hmm, so how control it from loptop?? Emulate android on loptop only??
2015-4-13
Raybro
You would need the Datalink to use it with the laptop and PC Groundstation version. The Datalink plugs into the laptop using a USB cable. The groundstation software then uses the datalink for communication with the Phantom.
2015-4-14
dave
Raybro Posted at 2015-4-14 22:53
You would need the Datalink to use it with the laptop and PC Groundstation version. The Datalink plu ...
So it is not possible to establish a USB connection directly between PC Ground Station and Phantom?
2015-4-19
Raybro
No. The usb datalink connection is used to transmit the GS waypoints to the Phantom.
2015-4-20
dave
Raybro Posted at 2015-4-20 19:23
Thank you for your reply. So short of investing $200 to $300 in hardware upgrades, there's no way to upload a mission to the Phantom? Wow. Unbelievable.
So on my v1.1.1 I'd need, what, the upgrade board, iOSD for a CAN Bus port and the BTU, plus the BT DataLink for my PC or iPhone?
2015-4-20
Raybro
I believe you are correct. For just groundstation you need the datalink. It comes with the BTU for use with an IPad. The datalink works on a PC with USB. The IOSD mini is only for telemetry.....battery...altitude...distance info.
2015-4-20
dave
Raybro Posted at 2015-4-21 06:44
I believe you are correct. For just groundstation you need the datalink. It comes with the BTU for u ...
Thanks again for your feedback. Looks like I'm best off just to ditch my P1 and look for a bargain on a P2.
This is disappointing news considering my $230 CX-20 was able to accept Mission Planner input right out of the box.
2015-4-21
