tom.loader
I recently switched over to Naza mode on my Phabtom 2 v2. I like the IOC modes!
my only problem is return to home... in Phantom mode I am stil lable to control it, so I can take over when it tries to land, but in Naza mode once it is returning to home I am not able to regain control.
I first discovered this when I attempted to launch from a clearing in some woodland, I turned it on and waited for good GPS, but then decided to launch from a different location, with fewer trees, but I apparently didn't give it sufficient time to acquire a new home possition before launcing. the battery dies sooner than I expected and it went into return to home mode... returning to the wooded area! I wa snot able to regain control, so I had to watch it crash it's self into the trees.
Fortunatly no dammage was done!
I have since discovered that if I use the toggle switch to activate return to home mode and switch back it stays in return to home mode and I am not able to control it.
Is this normal... or do I have somethig set up wrong?
