Malakai_UK
Flight distance : 536115 ft
A CW Posted at 2017-11-17 10:25
Looks are deceptive... I was configuring my settings in the app this morning to check everything over before it's first flight and the drone overheated and totally shut down with a solid red critical warning on the LED light turning on with a list of malfunctions... It was only turned on for less than 10 minutes. I let it cool down and turned it back on and it was all fine again. I then started calibrating the IMU and whilst the drone was positioned upright as part of the procedure the gimbal was vibrating very heavily and making a weird noise - it smashed my confidence in the drone completely so I took it back to apple today for a full and unconditional refund which they honoured. First drone I have owned that I have never flown. Disappointing is an understatement and so furious I didn't want a replacement. I've calmed down now and ordered the Platinum via DJI. If there is anything wrong with that one I will return it and it will be my final DJI purchase...
Did you have the gimbal cover on when it overheated? Behind the gimbal is a vent, if the gimbal protector is on the heat cant escape. Also, when you do the IMU calibration and have it upright they all make that noise, its the gimbal vibrating against the airframe because its trying to balance itself. When calibrating the IMU i leave the gimbal lock on to stop it being shaken around while I'm calibrating. Once the IMU is calibrated I turn the Mavic off, then remove the gimbal lock and calibrate the gimbal. |
