Cannot update firmware, device not detected
1837 5 2017-11-21
Namoh21
Flight distance : 90659 ft
Is anyone able to tell me what module 11 and 12 are in the update process?  I keep having these two devices show as "device not detected".  I know this bird crashed and has the shell replaced, so I would like to know if there is a cable I can check before needing someone else to replace a chip.  I'm not able to see anything that states what 11 and 12 are.  Below is a copy of the log from the last update process.
[00014635]========== remo-con disconnect. boot(15) ============
[00014711]Packet [C:\P3C_FW_V01.09.0200.bin] detected, card sn [0x98cd1190].
[00014779]Packet upgrade start...
[00014861]Packet checking...
[00014940]Packet vlink 01.09.0200 <-> 00.00.0000.
[00015020]Record vlink 01.09.0200 <-> 00.00.0000 (flow = 0).
[00015100]Done.
[00015172]Version checking[1]...
[00015268][04 00][00] v1.51.0.0 -> v1.51.0.0
[00027845][11 00][00] device not detected.
[00040421][11 01][00] device not detected.
[00040494][01 00][00] v1.14.4920 -> v1.14.4920
[00040570][01 01][00] v1.14.4920 -> v1.14.4920
[00040691][03 05][00] v34.2.0.9 -> v34.2.0.9
[00040803][03 06][00] v0.0.0.0 -> v2.4.20.50 need upgrade.
[00040929][07 00][00] v1.0.9.65 -> v1.0.9.65
[00041020][09 00][00] v0.1.1.1 -> v0.1.1.1
[00053592][12 00][00] device not detected.
[00066169][12 01][00] device not detected.
[00078753][12 02][00] device not detected.
[00091330][12 03][00] device not detected.
[00091405]Done.
[00093481]Waiting for user confirm...
[00103568]Timeout, start upgrade automatically.
[00103717]Firmware upgrading[1]...
[00104066][03 06] Firmware upgrade start...
[00503723][03 06] Firmware upgrade finished successfully.
[00503802]Done.
[00503883]Version checking[2]...
[00503961][04 00][00] v1.51.0.0 -> v1.51.0.0
[00516552][11 00][00] device not detected.
[00529133][11 01][00] device not detected.
[00529210][01 00][00] v1.14.4920 -> v1.14.4920
[00529283][01 01][00] v1.14.4920 -> v1.14.4920
[00529403][03 05][00] v34.2.0.9 -> v34.2.0.9
[00529511][03 06][00] v0.0.0.0 -> v2.4.20.50 need upgrade.
[00529635][07 00][00] v1.0.9.65 -> v1.0.9.65
[00529722][09 00][00] v0.1.1.1 -> v0.1.1.1
[00542421][12 00][00] device not detected.
[00554994][12 01][00] device not detected.
[00567572][12 02][00] device not detected.
[00580154][12 03][00] device not detected.
[00580226]Done.
[00580303]Firmware upgrading[2]...
[00580655][03 06] Firmware upgrade start...
[00975758][03 06] Firmware upgrade finished successfully.
[00975834]Done.
[00975904]Version checking[3]...
[00975983][04 00][00] v1.51.0.0 -> v1.51.0.0
[00988561][11 00][00] device not detected.
[01001141][11 01][00] device not detected.
[01001216][01 00][00] v1.14.4920 -> v1.14.4920
[01001294][01 01][00] v1.14.4920 -> v1.14.4920
[01001399][03 05][00] v34.2.0.9 -> v34.2.0.9
[01001519][03 06][00] v0.0.0.0 -> v2.4.20.50 need upgrade.
[01001651][07 00][00] v1.0.9.65 -> v1.0.9.65
[01001742][09 00][00] v0.1.1.1 -> v0.1.1.1
[01014316][12 00][00] device not detected.
[01026895][12 01][00] device not detected.
[01039479][12 02][00] device not detected.
[01052054][12 03][00] device not detected.
[01052130]Done.
[01052207]Firmware upgrading[3]...
[01052546][03 06] Firmware upgrade start...
[01451323][03 06] Firmware upgrade finished successfully.
[01451399]Done.
[01451473]Version checking[4]...
[01451564][04 00][00] v1.51.0.0 -> v1.51.0.0
[01464142][11 00][00] device not detected.
[01476718][11 01][00] device not detected.
[01476789][01 00][00] v1.14.4920 -> v1.14.4920
[01476868][01 01][00] v1.14.4920 -> v1.14.4920
[01476979][03 05][00] v34.2.0.9 -> v34.2.0.9
[01477123][03 06][00] v0.0.0.0 -> v2.4.20.50 need upgrade.
[01477228][07 00][00] v1.0.9.65 -> v1.0.9.65
[01477319][09 00][00] v0.1.1.1 -> v0.1.1.1
[01489891][12 00][00] device not detected.
[01502481][12 01][00] device not detected.
[01515057][12 02][00] device not detected.
[01527631][12 03][00] device not detected.
[01527706]Done.
[01527782]Firmware upgrading[4]...
[01528125][03 06] Firmware upgrade start...
[01925535][03 06] Firmware upgrade finished successfully.
[01925611]Done.
[01925693]Version checking[5]...
[01925889][04 00][00] v1.51.0.0 -> v1.51.0.0
[01938477][11 00][00] device not detected.
[01951052][11 01][00] device not detected.
[01951129][01 00][00] v1.14.4920 -> v1.14.4920
[01951206][01 01][00] v1.14.4920 -> v1.14.4920
[01951335][03 05][00] v34.2.0.9 -> v34.2.0.9
[01951433][03 06][00] v0.0.0.0 -> v2.4.20.50 need upgrade.
[01951531][07 00][00] v1.0.9.65 -> v1.0.9.65
[01951622][09 00][00] v0.1.1.1 -> v0.1.1.1
[01964203][12 00][00] device not detected.
[01976778][12 01][00] device not detected.
[01989358][12 02][00] device not detected.
[02001941][12 03][00] device not detected.
[02002013]Done.
[02002092]Firmware upgrading[5]...
[02002433][03 06] Firmware upgrade start...
[02399972][03 06] Firmware upgrade finished successfully.
[02400045]Done.
[02400122]Version checking[6]...
[02400208][04 00][00] v1.51.0.0 -> v1.51.0.0
[02412786][11 00][00] device not detected.
[02425360][11 01][00] device not detected.
[02425439][01 00][00] v1.14.4920 -> v1.14.4920
[02425518][01 01][00] v1.14.4920 -> v1.14.4920
[02425637][03 05][00] v34.2.0.9 -> v34.2.0.9
[02425736][03 06][00] v0.0.0.0 -> v2.4.20.50 need upgrade.
[02425836][07 00][00] v1.0.9.65 -> v1.0.9.65
[02425927][09 00][00] v0.1.1.1 -> v0.1.1.1
[02438510][12 00][00] device not detected.
[02451085][12 01][00] device not detected.
[02463664][12 02][00] device not detected.
[02476248][12 03][00] device not detected.
[02476320]Packet upgrade failed at firmware upgrade.
2017-11-21
DJI Susan
Per the upgrade log, it is the hardware issue, please start a case and send it in: https://repair.dji.com/en/SelfRepair/Area
2017-11-22
Namoh21
DJI Susan Posted at 2017-11-22 01:14
I figured that, I just wanted to know what module 11 and 12 were and if it might be just a loose wire vs needing a new center board.  Is that something you might be able to tell me?
2017-11-22
DJI Susan
Namoh21 Posted at 2017-11-22 05:05
It is hard to tell from the upgrade log. Once the unit arrived, the local team will do damage assessment to check the exact status.
2017-11-24
ChiukiAmsterdam
Flight distance : 7163576 ft
Did you ever get any further information from DJI as to exactly what that was - I see the exact same thing in my update log file.
2020-8-30
Namoh21
I did.  This drone (phantom 3 standard) happened to have crashed, which caused the battery connector to break off.  When the connector was glued back on, the 4 pins were not lining up correctly and causing a communication issue with the battery.  After repositioning the connector, the upgrade process worked.
2020-8-30
