DOWSETT
Flight distance : 392234 ft
The battery will not charge if its too cold or hot. If its is too cold or hot, and you plug it in to the charger it will not be accepted.
If you leave it on the charger; even though the charger has previously deem it incompatible, due to temperature.
It will stay incompatible till you've removed it from charger, and resubmitted |
