GPS drop when start video
681 4 2015-4-13
botero9
Ecuador
Hi I have aproblem with my phantom 2 vision+, everything if working ok but when I start torecord a video the GPS signals drop from 9-8 to 5-4 so the bird loose his wayto lock his position and I have to fly manual
Is up todate all the up dates any idea what is causing this.
Thanks
2015-4-13
nrgwise
That sounds strange - video should have nothing at all to do with GPS.  The circuitry is completely separate within the bird.  Does this happen in every area you fly in?  Just one area?  From what you wrote, you are already in the air and THEN you start recording?
2015-4-13
Gerry1124
http://forum.dji.com/forum.php?m ... cording&lang=en
2015-4-13
kirk2579
Flight distance : 37415 ft
I have not seen that issue for a few months , since the foil upgrade and , plug fix, and antenna upgrade
OP that is fixable just start look for some of the things above , many, many posts and fix
you can use alum foil  sheet metal tape from home depot.
digi-key for 931-1126-ND 4mm antenna
Wrap gps wire under factory shield and new foil to plug
2015-4-13
kirk2579
nrgwise Posted at 2015-4-14 02:49
That sounds strange - video should have nothing at all to do with GPS.  The circuitry is completely  ...
nrg
that was very common with v2 plus , not all had that but very common.  that's where the shielding upgrade the v3 has came from etc.
2015-4-13
