Nebuchadnezzar
Flight distance : 3462946 ft
From Randymajors POST
I had the same problems on both iPhone 5s and 6s, and these things fixed it for me:
In dji GO app:
- Ensure "Enable Hardware Decoding" in General Settings is set to On
- Disable Video Cache in General Settings
- Lower "Image Transmission Quality" to lowest setting under Custom in HD settings
Before you fly, in iOS:
- Shut down all background apps that are running
- Turn on Airplane Mode (be sure you've cached the map in the dji App for wherever you're flying before you do this)
- In iOS Settings, General, turn off Background App refresh
You could try doing some combination of these and see if it works, but I do all of the above and video transmission works consistently well and is of good quality on both iPhone 5s and 6s and with both Phantom 3 Pro and Phantom 4.
Hope this helps
Randy
