DocQuicksand
Flight distance : 1048652 ft
Bright Spark Posted at 2017-12-2 08:58
If you do use app you can enable it in menu, but there's not much point since you're in control anyway. It's for quick selfies in my view.
But if it loses you ( it only tracks you for 15 metres or so ) you can rescue it with rc/phone.
Sounds a bit sketchy. Knowing that the tracking feature uses image contrast to maintain the target, it is hit and miss based on the conditions (dark on dark, light on light, light on dark, etc). I don't plan on using it too much anyway, but I appreciate the input. I will still give it a test run just so I know that it works... |
