altermaan
Switzerland
Hello everyone!
I did something very stupid today: I accidentally flew my Mavic Pro into my bed while trying to show it to a friend (don't ask...). After it hit the frame (or the mattress, not sure which came first, but probably the frame) with the right rear propeller, the motors stopped and it basically made a somersault onto the mattress (also not entirely sure which happened first).
Luckily, aside from the right rear wings I did not discover any visible damage to the drone . Also, it's still flying normally in my opinion. Now, the question is:
Do you think the motor(s) (at least the right rear one) or other component(s) might have taken some internal damage I'm not seeing? Is there any way to run a hardware test (similar to Apple's AHT, for example) to check for possible internal damages? My fear is that everything seems fine until at some point the Mavic starts acting up while high up in the air, hundreds of meters away, which I'd like to avoid!
What do you think?
Cheers,
Daniel
