Genghis9
OK box361
I'm going to give you a small crash course in aviation ops and pressure altitude factors
First, yes, your P4 is software limited to 500 meters or about 1600'; the very important factor with that is it is above the takeoff elevation. In other words, if you take off at sea-level you can go no higher than 1600 feet MSL (Mean Sea Level) which would also be AGL (Above Ground Level).
Therefore, if you go to the top of Pikes Peak and takeoff you can ascend to an altitude of 15,715 feet MSL, yet, you will only be going to an altitude of 1600 feet AGL
I'm thinking at this point you have figured out that you can fly to much higher altitudes than you might have been thinking otherwise. So, here is the next factor to consider. I'm not going to go in to all the various calculations to support flight performance factors etc. etc. so here is the quick and dirty. The higher you go the thinner the air, the thinner the air the harder it is for air foils to produce lift and in this case for a quadcopter it makes it more challenging to maintain stability. All that means is that DJI has determined that at 19685 ft MSL the quad cannot fly reliably enough to sustain controlled flight. This makes that altitude the P4s max operating ceiling.
Lastly, do not confuse operating limits, with design limits, software limitations, and regulatory limits. All in all if a P4 has a range of say 4 miles then it should easily be able to fly to an altitude of 21,120 above your takeoff point and from your Remote Controller. However, DJI through FW has limited your ability to fly no higher than 1640 feet above the take off point, and the rest has been discussed or noted.
If you modify the SW you will negate the warranty and any hope of DJI supporting you if something goes wrong.
In your example, if you attempt to takeoff in a valley and then fly to a mountain 900 feet higher you should be able to. FAA rules are 400 feet AGL and the mountain is not higher than the takeoff point by 1600 feet. |
