DocQuicksand
Flight distance : 1048652 ft
Will say also, as a general rule of thumb, just make sure that you follow the FAA guidlines and you can't go wrong. Biggies are:
- Keep it below 400' (unless flying near a tower, then you have an additional 400')
- No flying over people (unless permission is granted first, or if it is your visual observer)
- No flying over sporting events, stadiums, etc.
- Always give way to manned aircraft.
- Always maintain direct line of sight with your drone, do not count on the onboard camera for navigating.
- Pay attention to the Airspace Zones in which you are flying - Note that most Airspace is restricted, NOT off limits. You can actually fly in restricted airspace as long as it doesn't interfere with manned air traffic patterns, with ATC approval (just a phone call).
- You can actually get Airspace Maps with data that is updated daily, sometimes twice daily in larger areas.
If you follow the first five rules mentioned above, and are using your drone for recreational purposes, you are mostly safe. I would recommend that you look in to FAA paart 107 for informational purposes, even if you do not wish to get a commercial license. I fly in San Antonio, Texas (fairly large city) and have never encountered a problem. There are other things that you may want to consider. If you plan to fly over and film a structure on Federal land (National Park structure - Alamo), it is a good idea to contact them as a courtesy (even in unrestricted air space) to let them know your intention. Gives them a warm and fuzzy to know that you didn't try to go behind their back which can surprise them and cause a situation that they feel they have to react to. Either that, or just play dumb when they come asking what you are doing.
Enoy your road trip, and happy flying!
DocQuicksand
